How to fit diagnostic port to Mk2 VR6? NOW DONE!!
Discussion in 'Electrical' started by 1990, May 7, 2009.
  1. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Excellent, thanks:thumbup:
  2. rocco2litre
    rocco2litre Forum Junkie
    dont you just wire it into ecu? from the vr6
    brown to earth, red to +12v (bat) and onto grey, and yellow wires from ecu
  3. rubjonny
    yes you do, the jumper block is just a way to connect the 2 together. the reason vw use the jumper block is there is more than 1 item that needs to be connected to the vag com plug (abs, airbags, ecu plus loads more on later models) There are only 2 diagnostics wires into the plug, so the jumper block allows all these extra things to be plugged in.
  4. 1990
    Rochdale, Lancs
    YES!!! It works!!!
    G28 - Speed sensor was the only engine fault code
    Thanks for all the help:thumbup:
  5. pRot3us Forum Junkie
    Wales
    Which is normal if its an OBD1 and the engine wasn't running at the time. :thumbup:
  6. 1990
    Rochdale, Lancs
    Bummer, I was hoping for a clue as to why its running rich and slow, limp mode?
    Here are a couple of screen shots:
    I have no idea what any of it means. Other than checking fault codes and clearing them i'm clueless.
  7. Collie Forum Junkie
    Adlington Lancs
    well done getting it working,
    Have you thought about doing some maf logs?
  8. 1990
    Rochdale, Lancs
    Yes, i just need to find out how to do it first[8(]
    Are there any online Vag-Com instructions?
  9. rubjonny
    Cool glad to hear it worked :)
    Quite a bit of info to be had from ross tech common diagnostic procedures site, also a link there to the rosstech wiki which has info on most of the fault codes.
  10. G60KG
    G60KG Forum Member
    at work 'working'
    you get live data by going into the engine module and then into measuring blocks. I think this function may only be available after a certain year. It does not work on my 94 Corrado using the 2x2 adaptor
  11. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    I plugged all mine in at the weekend and it didn't work...
    I have the loom pretty much in tact for the port and went by the wirin diagram.
    Mine is just lime yours in the pic jonny.
    Does the black plug need to be plugged in as I'm sure I already hav somthing in that port.
    All I was doing is the k-line from the ecu into the black connector block thing and the. My port plugs into that too.
    A random live and earth and my vag-com lead lights up.
    It cannot find the engine controller though. Does my bag-com lead need to be an obd1 or are they backwards compatible?
    Cheers
    Mat
  12. rubjonny
    obd1 and 2 are the same on the mk3 ecus, just a case of making sure the ignition is on and the diagnostics wires are plugged in correctly
  13. mat-mk3
    Bristol
    Welcome back Jonny!:lol:
    I took my diagnostics loom apart and found out they had spliced it into plug "L" for some reason.
    It had a mix of sunroof plugs and stuff on it.
    Taken it right back to just the live, Earth and Grey (K-Line) wire now and will test it at the weekend:thumbup:
  14. rubjonny
    chees, slowly working my way thru the email backlogs :lol:
  15. mat-mk3
    Bristol
    Had a spare 5 mins today so connected my loom up. (Ive run out of earths!)
    Got it all working and no faults at all to be seen![:D]
  16. vicogti New Member
    SLO
    Guess I'll rather hijack this thread than open a new one.
    I'm doing an ABF swap, and so far I have spliced the immo wiring from rest of the loom (it's form a 96 Passat, hence the color difference, I think)
    It looks like this:
    As I understand:
    - the brown cable on the lower right is ground
    But this I don't understand:
    - the black cable (n. 5) goes to pin 43 on the ECU (the green wire)?
    - the 16 pin connector (n. 3) is diagnostic port?
    - how do I wire up connectors 1, 2 and 4? I dont have the junction block shown above...
    - what about the red and brown wire on 16 pin connector?
    I know it looks a bit stupid, but I just cant figure it out [:$]
    I hope someone could help me out.
    Cheers
  17. infinity
    infinity Forum Member
    what does the grey wire do from the immobiliser unit (connected to to tv14 connector?)??
  18. rubjonny
    its a diagnostics passthru, ecu diagnostics wire plugs into the immob box first, so immob box and ecu can communicate. then there is a wire from immob box to tv14 junction block, which is how vag-com can read cdes from the ecu and immob box
  19. Toyotec
    It is the K line that, which has a std position on any J1969 coporate diagnostic contector ( called by the street as "OBD2" jack). This typical std found on any VW/Audi vehicle post 1994. The K line daisy chains with climate control, ABS or any other controller that speaks in KWP 1281 or 2000 protocols. On this type of connector you can find the grey/white to be on pin 7 of the J 1962.
    You would also require pin 16 to have +12v and a vehicle gnd on in pin 4.
    Typical wire pin out of a J1969 connector.
    Pin 43 of the PCM requires a checksum from the immobiliser to authorise ECU operation. It shares this data on the same K line as the ECU diagnostics.
  20. blis Forum Member
    New South Wales
    TOLEDO ABF - DIAGNOSTIC INTERFACE - TV14 - Terminal for self-diagnosis
    TOLEDO 16V ABF - To add, the wiring on our ABF SEAT Toledeo - Diag Signal - LIME or LIGHT GREEN on pin 43.
    Ive hooked up VCDS Lite briefly and with a LOT of fooling around it did detect both ENGINE and IMMOB in the AUTO SCAN section and it dumped text that it was recognized.
    At one point when I thought I'd found the ECU and all was good, checked ENGINE and there were no faults found. Hard to believe really... so will revisit the ECU with VCDS and get some screen shots etc.
    I had to stop, a teenager complaining that he expected Graphical RPM Tachometers, bling and gauges, it was cold, I was tired too, went googling for other Diagnostic systems... VCDS is all there is right?
