By fitting a dieselcrank stroke go from 92,8 mm to 95.5 mm So the piston comes 1.35 mm higher above the bloc deck , this means that you need other pistons with the correct height to compensate it
I was being slightly cheeky tbh Hugo. By saying "just" or "simply", it was so that the original poster could hopefully see it was anything but simple, or cheap!
Having the pistons 1.35mm higher could be construed as an advantage, as it can be more expensive trying to get the compression up than down. I have recently been there, with 2mm off the top of a tall block costing me an arm and a leg, while I can modify pistons at home on my fairly modest lathe. Important thing is measure measure measure Jon
I didn’t know weather there was a different crank/pistons that would fit the 2.0 block before you start making it bigger/boring it out.
Thanks for your wise words so there is no easy way of doing this just i would love one of the tsr 2.1 engines but they are expensive
As Tristan says above, no real world difference going to 2.1 when a 2ltr tugs along quite nicely, unless you just really fancy one...nothing wrong with that. STD 2ltr 82.5mm bore and diesel crank will give 2042cc, 83mm bore will make 2067cc, 83.5 bore will give 2092cc, but bores getting thin and piston availability even thinner. Custom pistons are an option but not cheap.
