How to up 15/20 hp in 1.8 gti k-jet?
Discussion in '8-valve' started by andre82, Dec 26, 2010.
  1. andre82 Forum Member
    Hi guys,
    i need info for up 15/20 hp in my golf
    now i have installed complete exhaust sistem, manifold powerful and center pipe whit rear exhaust whit 16v diameter
    k&N panel air filter,
    What else should I mount? or that changes can I do?
    (modified not very expensive and not complicated if possible!)
    have links with the FAQ?
    Thanks
    PS. i'm from Italy sorry for bad english,
  2. geneticmaterial
    geneticmaterial Forum Member
    Skipton
    Probs look at 2.0 ltr bottom end for an immediate increase dude?
    I R CLICKABLE
  3. pigbladder Forum Addict
    cambridge , uk
    yeah an honest 20hp isnt easily come by , the cost of a decent flowed head and cam would be more than a 2.0ltr from a junk car
  4. Admin Guest
    I upp'ed my power in my mk1 from the stock 1.8 DX engine at 123bhp to 140bhp by fiting a 2l bottom end and cam.
  5. gosy New Member
  6. andre82 Forum Member
    HI,
    thanks for the info,
    2.0 L conversion it's cool but is very expansive, in'italy is not easy find the parts and the workshop is more expansive for make this work!
    if change the cams?(7/8hp)
    exist a bigger throttle? If possible modified my throttle?
    How can I increase the fuel and fuel pressure?
    thanks
  7. Admin Guest
    you could go big valve head with a wild cam, larger Audi throttle body.
    not much you can do with the std K JET system to gain any real power out of it for decent money.
    I don't know how much a 2l conversion would be in Italy, but the other route, listed above, would be as expensive in parts.
  8. andre82 Forum Member
    what Audi I look for the throttle?
    audi throttle and cams it's good modified, approximately 15hp?
  9. Admin Guest
    same Audi that you can rob the brake carriers from.
    the old 80's and 100's, the ones with the same DX engine in the bay. 2.2 from memory?
    think you'd be lucky to get 15bhp from that....
  10. shaz8389
    shaz8389 Forum Junkie
    A 16v swap :thumbup::lol:
  11. Admin Guest
    he said he wanted more power.
    but if a simple 2l swap is to much money, will a 16v be any more economical?
  12. R.b!n_16v Forum Member
    I run digifant 2, is there a audi throttle bodie that fits mine?
  13. Admin Guest
    the throttle body is just for the larger butterflies.
  14. andre82 Forum Member
  15. Admin Guest
    will dig out partnumber for you
  16. StuMc
    50? 20` 47 N - 06? 57` 57 E
    An extra shim or two in the fuel pressure reg on the side of the metering head, and advancing the timing accordingly netted me 17bhp. ;)
  17. andre82 Forum Member
    have photo of this modified?
    thanks
    thanks jon await part number
  18. 3hirty8ight Forum Member
    :lol::thumbup:
  19. Admin Guest
  20. jamesa Forum Junkie
    Abz
