I've managed to get all the pedals sitting about the same level Trev does the brake pedal sit higher than it should??
[shushhhh] The brake pedal needs the servo bolting onto it to make it sit at the right height.... [/shushhhh] Edited by: FaTT mk1
i had this problem too trev. Its out by quite a way from hitting the switch. I 'crafted' something to extend the servo arm a bit. I will try and dig out some pics, its jut finding the time atm
not sure that would have worked on mine at least. Was quite a gap. I've faffed around with all the pedals. All line up nicely now though...finally Edited by: thebluebus
Well I went and looked at the brake sensor switch. Thought to myself that it looks just like an ordinary pushswitch and there's no way that you could adjust it in any way. But sure enough, if you pull the plunger it ratchets out by up to an inch! Many thanks mate!
