ISV Cleaning
Discussion in '8-valve' started by sdall30, Sep 24, 2008.
  1. sdall30 Forum Member
    Worcester
    I've seen various post about a dirty ISV causing hunting at idle on *v GTI's , well mine is doing this . I want to clean the ISV and I have no trouble removing it from the car .
    However I don't want to damage it so what is the correct way to clean it and where can I get Carb cleaner from ..
    Thanks
    Stuart
  2. t'mill Forum Member
    Cardiff & Darwen, Lancs.
    You can clean it by leaving it connected to the electrics but removing it from the hose and submerging it in petrol. Use a jam jar or shallow tupperware for this. Then turn the ignition on so current is going through the isv (buzzing) and leave for a good 2hrs.
    Then shake all the black crud out and maybe squirt the carb cleaner (any car shop sell it) to get the last cack out.
  3. 1982.rpd Forum Member
    Air leaks also cause this have you checked vac lines ect.....
  4. RIP-MK3 Forum Addict
    sunbury on thames
    some one on hear posted saying carb cleaner possibly isn't a good idea, use petrol only
  5. sdall30 Forum Member
    Worcester
    check all vac lines and replaced a couple I thought were suspect., will give it a good clean tonight
    sorry to sound like a complete numptey but would I have to leave the engine running or just the ignition on ?
    thanks chaps
  6. nickh89GTi Forum Member
    Exmouth
    Just turn the ignition on and leave it for 1 or 2 hours.
    Think it was Rubjonny that said carb cleaner was to harsh/damaging for cleaning ISV's.
  7. rubjonny
    I have said it, but I read that on here somewhere as well :lol:
  8. RIP-MK3 Forum Addict
    sunbury on thames
    this site is just second hand information recycling around (i'm the worst at it lol)
