ITBs and Digifant 3.2?
Discussion in 'Throttle bodies & non-OEM ECUs' started by GTI, Dec 1, 2004.
  1. GTI
    GTI Forum Member
    Shropshire
    Seeing as Digifant 3.2 used a TPS instead of a MAP sensor, I guess it would be fairly straightforward to use it with ITBs, or am I missing something?
    I mean, if you got a set of ITBs bolted up to an ABF in a Mk3 (which already runs Digi 3.2 afaik), whould it then just be a case of connecting up the fuel lines, sorting the electrics and getting a custom remap? Could it run at all on the standard map?
  2. prof Forum Addict
    Suffragette City
    basically yes but it's a lot of R&D and you need to find someone who will map it, see Waynes comment of the other thread. The guy who used to work at AMD reckoned about 600 worth of mapping/rollers time to get it right.
