k jetronic brass idle screw
Discussion in 'K-Jetronic OEM injection' started by dubztubz, Nov 22, 2015.
  1. dubztubz Forum Member
    ireland
    does any one know the size of the rubber o ring for the brass screw
    seems vw only sell the brass screw its self
    if you can get a screw from VW it will come with the seal, but probably all NLA by now. I just got a big box of orings and used the closest match :)
  3. Ben_s Forum Member
    I did the same thing. Bought a huge box of o-rings. None of them were quite right so put a couple of wraps of ptfe around the screw and then used the best fitting o-ring from the box.
