Kjet injector thread size
Discussion in '8-valve' started by Mk2 driver 1800, Aug 7, 2021.
  1. Mk2 driver 1800 New Member
    Hi everyone I'm planning on putting in a kjet gti engine on weber carb into my mk2 golf after having years of problems with my driver engine my m8 has sent me a link to some gearbox drain plugs on ebay but they come in sizes m12 m13 m14 m16 m20 and m22 I'm not sure which size I would need to block the injector holes in the head
    M24x1.5 for a VW box drain/fill plug. sort of tyhing you can get out scrappy, take a 17mm hex with you or a wheel bolt and spanner
  3. KeithMac Forum Junkie
    Kazakhstan
    The aren't in the head they are in the inlet manifold. You used to be able to buy proper plugs a long while back.
    You migh be best off finding a more suitable inlet manifold?.
  4. 2swe Forum Member
    Czech Republic
    the injector inserts have M22x1,5 fine metric thread.
  5. rubjonny
    The MK1/2 injectors are in the head, it's mk3 2.0 they moved to the inlet
    also the gearbox drain plug does definitly work for some injector ports, but now I think about it there may be 2 sizes depending on the age. easy to tell if its m22 or m24 just measure the diameter of the hole/insert
  7. KeithMac Forum Junkie
    Kazakhstan
    There's cutouts in the head but the actual injector boss is part of the inlet manifold?.
  8. rubjonny
    That's a 16v head, this post is in the 8v section ;)
    KeithMac likes this.
  9. KeithMac Forum Junkie
    Kazakhstan
    Ahh sorry, god knows why I assumed it was 16v!.
  10. Mk2 driver 1800 New Member
    Thanks for the reply got the drain plugs the other day so should be good to go soon putting a new water pump and cambelt on aswell then shes going in so fingers crossed it's a good moter.
