KR with AGU fuel rail....
Discussion in '16-valve' started by Shugged, Dec 29, 2023.
  1. Shugged New Member
    Hi All,
    I am currently in the process of building my KR engine to run on EFI via an Omex ecu. Without doing much research i bought an AGU Fuel rail with injectors. For now I want to keep the standard inlet manifold and use the injectors and fuel rail I bought, I have seen people use these successfully using injector extensions or 'top hats' however this seems to have been prevalent in the late 90's/early 2000's and not so common these days.
    Does anyone know where the correct 'top hats' can be purchased?
    I have looked around for BBM items but they are pretty rare and not available on their website.
    TIA
  2. dogzila Forum Member
    Use G60 plastic inserts
  3. rubjonny
    037133555A, same as used on the normal digi engines as well plus a fair few others across the range
  4. Shugged New Member
    Thanks Guys. I think I may be using the incorrect terminology for what I require. I have got the G60 plastic inserts which fit, what I require is a spacer to allow the fuel rail to sit away from the injector itself like the image attached.
  5. KeithMac Forum Junkie
    Kazakhstan
    You might be better off looking for a BBM fuel rail (used in their 16vG60 kits).
    Very good quality and a great fit.
  6. Shugged New Member
    yeah i think that's the way i'm going to go. Thanks.
  7. KeithMac Forum Junkie
    Kazakhstan
    Can't find a decent picture but I've had mine over 17 years now.
    Just gone over to Bosch EV14 injectors (550's).
  8. Shugged New Member
    Thank for the pics Keith. I'm talking to someone from the US who is going to send me a bbm Rail.
    KeithMac likes this.
