Lairy Rev Counter
Discussion in 'Electrical' started by Beastlee, Oct 25, 2003.
  1. Beastlee New Member
    We have an 89 (F) 1.8 16V that has a crazy rev counter.
    If you accelerate or remain at a constant speed it's fine but the moment you release the accelerator it shoots round to 8K RPM and then back to where it should be. This happens every time you lift your foot off.
    Anybody got an idea what is wrong with it?
    Thanks
    Lee
  2. 8v steve Forum Member
    i have a 1990 digi with the same problem
    the rev counter fly`s all over the place if i turn the engine off and restrt it its ok for a bit then it happens again ???????????????????????????????????????
  3. Phil
    Phil Forum Member
    Ont tinternet.
    Try changing the speedo drive?
  4. 8v steve Forum Member
    sorry for sounding dumb but how would that help i thought the rev counter was electrical
  5. Phil
    Phil Forum Member
    Ont tinternet.
    It might not be picking up correctly from your gearbox. That would make it flick, when not at a constant speed.
  6. Beastlee New Member
    We're talking Rev counters m8, not speedos. The rev-counter runs from the coil as far as I'm aware, nothing to do with the gearbox.
    I know that on French cars in particular tend to shake if you ever disconnect the speedo drive but I don't think this would be related on a Golf.
    Lee
  7. 8v steve Forum Member
    also the car has started to cut out at low speed ie 1 gear almost like ive turned it on and off really quickly but i dont get the battery light come on the dash or the temp light could it be the fuel pump or the injection ?
  8. Phil
    Phil Forum Member
    Ont tinternet.
    Sorry. was still half asleep when I posted that. [|)]
    Edited by: Phil
