mk3 golf - central locking - de-locked - Toad ai606 alarm/immobiliser Just got home after driving with doors locked. Pressed alarm fob to unlock doors. locks made all the right noises but none of the door pulls inside or out will open the doors. Just had to climb out the window. If I can get door open then I can get inside it and see what is going on. Any advice? I wouldn't normally post my number but I'm quite desperate as you can imagine! Thanks
cool, it made me laugh at first i thought you were actually trpped inside using you iphone to ask cgti haha lmao!
I'm chuckling now but at the time had me stumped. Didn't know what to do! At one point (whilst I had the window down) my neighbour walked past. After trying to look busy (casual look in the center console/glovebox/down side of seat) and making sure they were gone I quickly bailed out the window. Got in the house, in a panick posted on here with an eye catching title, then figured it out over half a mug of tea, went back out and sorted it. Good old tea eh - the answer to every true Crisis. Oh, then panicked again when I remembered I'd just posted my mobile number on the web! Quick edit and the rest of the brew later and second problem sorted.
Previously, if locked from inside I could either unlock by lifting the pin or lock and then unlock using the alarm fob. It seems that the latter version no longer works. The reason I didn't work this out earlier is that a while ago I accidentally snapped the door pin. Now when the car is locked the door pin dissappears within the door and you can't get hold of anything to pull it back up.
FFS! Passengar door still won't open. It sounds like it unlocks but both door pulls feel the same as when it is locked. Could it just be that the latch inside has become dissengaged from the pulls? Or something else? So I'm stuck with a closed door so can't get the door card off or get to the lock. What do I do??
