Lower bracing, strut brace
Discussion in 'Chassis' started by basilknife, Feb 26, 2024.
  1. basilknife Forum Member
  2. PhilRyder
    We had a lot of torque steer but a change of tyres almost eliminated it.
  3. basilknife Forum Member
    Reallly? Did you change tyre size? Or just brand?
    Iam on 205 50 15 Yokohama advan ad08.
    I have thought about bigger wheels/tyres but I want to keep the bbs’s
    What car/engine can I ask also?
  4. PhilRyder
    Just brand. Michelin sport pilot 195/45/15. MK2 golf 3.2 VR6 277hp
  5. PhilRyder
    Error, they are 195/50. A taller side wall will likely increase torque steer, also a softer sidewall. 205\50 gives you a side wall of 102.5mm, 195/50 is 97.5mm. Not much difference but some. I did notice that the Michelins had a stiffer sidewall over the Toyos. The age of your tires will make a difference too, harder and worn is no good for grip or directional stability.
  6. basilknife Forum Member
    Thanks for the info on the sidewall. 195 vs 205 wasn’t something I had considered. Nor was brand change either! my current tyres have a fair bit of life in them still and will have to get my moneys worth out of them before new ones
