Lupo throttle response....or lack of
Discussion in 'Fox/Lupo/Polo' started by CovGTi, Nov 27, 2012.
  1. CovGTi Forum Member
    Coventry
    Hi all,
    Every now and then the lupo throttle pedal doesn't respond. I put my foot on it to accelerate and nothing happens. The car returns to idle and doesn't stall.
    Someone mentioned the potentiometer, but need a second/thrid/fourth opinion please.
    Or any other ideas. I get the feeling it wont be a cheap fix.
    I need to be sure, as i dont have the money to throw at it changing randon parts in the hope it solves it.
    Thanks
    Carl
  2. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    cam timing if it's a 1400 twin cam, cat broken down fuel filter blocked?- get it scanned?
  3. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Are you getting an ECP light?
  4. CovGTi Forum Member
    Coventry
    No, nothing.
    The problem is intermittent too :(
  5. tshirt2k
    Herts
    I've had a similar problem with mine but i usually disconnect and spray connectors on TB with wd40. It should show a fault code.
    yep get codes read first, sounds to me like throttle pedal or wiring wants looking at
