Measuring crank shells
Discussion in '1.8 & 1.8T' started by Savagesam, Nov 18, 2020.
  1. Savagesam
    I’m in need of your help.
    I’ve done a little test, and this is my first result.
    Which reads at like 0.038mm. Maybe a little less.
    Here are the clearances shown from the manufacturer.
    So what does this mean? Where do I go now? The engine has standard shells in, I believe I’ll have to double check, they are stamped Audi though.
    I’ve never done this before and my research doesn’t seem to be taking me anywhere...
    *I’m yet to measure all 5 caps, I will do this later on*
  2. davidut5 Forum Member
    Romania
    Where is the problem? Spec is 0.01-0.04 when new and 0.07mm wear limit, you have 0.03mm.
  3. Savagesam
    There isn’t a problem. I just don’t know if that means I just get new standard shells, or move to the next size up or whatever. I just wanted advice on that really.
    so I guess I just buy new standard shells, new bolts and bung it back together.
  4. davidut5 Forum Member
    Romania
    As now it is not new, it is still well under the max wear limit of 0.07. For next size shells the crank would need grinding but it is not needed. New std shells sound like a good idea.
  5. Tristan
    Standard shells, and send it.
  6. Savagesam
    Ah okay, that’s what I wasn’t sure on. I didn’t know if the next size shell meant a regrind or not.
    Marvellous. Any recommendations on brand?
  7. Tristan
    Ks / KolbenSchmidt, Mahle
  8. Savagesam
  9. Tristan
  10. Savagesam
    Oh everything I read was 0.25 was standard. Oops!
    Crank is out, I was going to do it myself, not sure how yet but can’t be that hard.
    If the big end is the ones with the caps into the block, then yes!
  11. Savagesam
    Euro car parts offer elring ones for £38 so I’ll get those
  12. H8V
    h8v Forum Member
  13. Savagesam
    £5 postage, much easier for me to drop into euros on the way past tomorrow for the sake of £3.
  14. Savagesam
    How do you go about polishing the crank?
  15. H8V
    h8v Forum Member
    Ah yes, it used to be free postage for anything, and dhl often delivered it the next day.
    Savagesam likes this.
  16. Tristan
    I send it Jerry Mccarthy Engine Reconditioning:lol:
    Big Ends are the bottom of the Conrod, Mains are the ones that bolt into the bottom of the block.
  17. costel1969
    No messin' with Jerry McCarthy - I can vouch for that albeit not much use to Sam
  18. Tristan
    Jerry does all my engine machining. Top notch people.
    Sam, apparently you can polish Crank journals with fine emery paper, while spinning the crank in a lathe.
  19. Savagesam
    Ah yes, Jerry he’s my best mate... nope I’m out, no idea who he is!
    I don’t have a lathe so that’s out.
    Do you think it’s needed? It’s super smooth no putting or anything.
    it’s on each journal.
  20. Tristan
    That doesn't look brilliant..
