MegaSquirting AGU 1.8 20v Turbo
Discussion in 'Throttle bodies & non-OEM ECUs' started by Mad Professor, Mar 7, 2010.
  1. Mad Professor New Member
    360deg / 60teeth = 6deg per tooth.
    14teeth (6*14) = 84deg.
    19teeth (6*19) = 114deg.
    as said above I am and will be using MS2-Extra.
    Here is a quick screen shot of the Trigger Wheel Settings page in MegaTune.
  2. bens_cab Forum Junkie
    Ashford kent
    ms2 looks a bit to involved for me lol
  3. bertelli_1 Forum Member
    near the rev limit
    My figures shown in the table above were checked & double checked by my good self, using a timing wheel. No 'internet facts' were used. I can guarantee they are correct.
  4. bens_cab Forum Junkie
    Ashford kent
    Ant didnt i send you them settings lol
  5. Toyotec
    You are correct on the CA for tooth 14. Dont know why I thought it was 5 deg per tooth segment.
    The position of the pickup dictates when tooth is TDC so other vehicle makes will be different.
    You can confirm what we have said by removing the VR sensor and #1 spark plug, place a long thin screw driver into the plug hole, locate the missing tooth and start count the teeth until you are TDC. You would confirm what we said here that TDC is on tooth 14 and match your ECU configuration to suit this hardware requirement.
    Hope you can now progress.
  6. bertelli_1 Forum Member
    near the rev limit
    haha! If you did, they'de be Eddies settings anyway!
  7. bens_cab Forum Junkie
    Ashford kent
    eddie got them from me lol yeah ok so he fixed them alot lol
    whod have known that megasquirt would have taken of so well in the 20vt i nearly gave up and that was 5 years ago glad i stuck with it
