I've just fitted a set of early 2 plug clocks with an MFA, but unfortunately I don't have the little connector for the MFA stalk in my dash, I don't suppose anyone here knows how to wire these up? I assume it connects to the dials thru the 2 plugs at the bottom. Also the vaccum tube that should connect to the back o the clocks is missing does anyone know how to connect this up on a I have a 1.6 Driver? I there anything else I'm likly to need like the outside temp sensor etc?
the 1.6 driver doesnt have a vacume feed for the clocks, you will probably have to run one off from your carb or something similar. you will need the outside temperature sensor, i dont think the oil temperature sender will fit in the 1.6 block, but there is a thread on how to put a oil temp sender in to your sump plug for wiring up the MFA stalk to the clocks is really easy. all you need is this, that i found a couple of weeks ago Click HERE
