misfire/popping mk3 8v (agg)
Discussion in '8-valve' started by beni-iow, Aug 20, 2008.
  1. beni-iow New Member
    isle of wight
    hello there ive got a 96 golf gti 8v with a agg engine in it.when the cars stationary and i just blip the throttle a few times it missis and pops.but when i am driving (giving it some) and change gear fast it dogs down then picks up again could this all be related.any help would be greatfull
  2. garnetteyes Forum Member
    Nuneaton
    Crank sensor?
  3. rubjonny
    get it on vag-com!
  4. ^neo^ Forum Junkie
    i had the same problems with mine.
    Hard to say what the problem was as i changed most of the 'known culprits' in one swoop.
    Plugs, leads, dizzy cap, rotor, crank sensor, knock sensor, fuel pump relay, ecu relay & fuel filter.
    Crank sensor wiring was completely shot, all 3 wires had the insulation broken and were touching each other, which probably didnt help!
