MK1 Golf VR6
Discussion in 'Members Gallery' started by moley mk1, Oct 22, 2007.
  1. prof Forum Addict
    Suffragette City
    proper monster then :thumbup:
  2. nutter4x4 Paid Member Paid Member
    Lao Peoples Dem. Rep.
    scary is all i can say
  3. prof Forum Addict
    Suffragette City
    excellent i'll come along for a fright, don't break it before inters then ;)
  4. paul_c Forum Member
    I never used the subframe, I cut the engine mounts off it and welded it directly onto the Mk1 bodyshell (with some more custom fabricated stuff too).
    The radiator is a Passat diesel rad, its the same width as the VR6 rad but less tall. I turned it upside down (so the hose connections are on the other side) and chopped off the little pegs/locators (now on top) then fabricated little slots to sit it on the front panel. Then cut a little off the back of the top area on the front panel (and strengthened it later) so the rad can sit much further forwards. The fan housing is a cut down Mk3 Golf one (its just plastic/fibre, easy to trim) and everything connects up really nicely that way. You also gain the twin fan VR6 setup that way too.
  5. moley mk1 New Member
    Awesome!!! thanks for the info
  6. moley mk1 New Member
    Time for another update i thought. Still been cracking on with the body work, the passenger sides sill and arch have now been replaced and the lower section of the rear valance too.
    Out with the old
    In with the new!
    I have ordered my new wheels[:D] and coilovers, you will have to wait and see what wheels they are:p , but the coilovers are here. I may have to do some arch mods, so the body work has now come to a stop till the wheels arrive.
    I have now turned my attention to the fuel tank and underneath of the car.
    I had to mod the fuel tank to be able to take the VR6 pump, which basically meant cutting a hole in it.
    Also to stop the pump moving in the tank i made a litle cage for it to sit in, not the prettiest, but it will do the job!!
    The cage
    I also cleaned up the rear axle.
    The rear axle was not as wide as the mk3 (as im using the mk3 front subframe the rear needs to be wider) so i fabbed up some spacers to that go between the axle and the stub axles, now gone from 1292mm to 1360mm, wide track ahoy!!! I couldnt believe that mk1 and mk3 stub axle holes all lined up, easy peasy swap!
    All painted with other rear axle bits too.
  7. MITCH-MK3 Forum Member
    croydon
    looking good mate !! what you doing with your vento bonnet and headlights ???
  8. moley mk1 New Member
    The vento i bought was basically a running shell. It had no doors or anything. It was quite fun driving it around the fields sat on a wheel with no doors, seat belts or glass!!! Sorry i cant be of any help.
  9. moley mk1 New Member
    Just a quick update, today i took deliver of a set of these bad boys, schmidt modern lines 15 inch, 8j on a 195 50 yokohama, to give a nice bit of stretch!
    Now its time for some wide arch action!
  10. GVK
    I think you need to post a pic of the turbo that's on it too Pops, :lol:
  11. nutter4x4 Paid Member Paid Member
    bumpage ,
    so wots goin on with the mk1 vr`s ?????
  12. golfmantobes Forum Member
    mines still on the go, shell's just in the middle of primer coats, should start puttin it back together within the next couple weeks! and hopefully be ready for start of show season next year?[:s] I will post more pics up on my page when i get them off my phone.(dont want to hijack this thread:p )
    Not sure whats happened to paul c's or anyone else's builds...?:o hopefully there all still on the go
  13. Vento Mike Forum Junkie
    Exmouth
    I know of a nice 24v vr6 on Itb's coming along quite nicely, no pics tho sadly!
  14. 91davidw Forum Member
    Northern Ireland
    Dead thread from 2years ago, did you get it finished ???
    Cheers
    David
  15. nutter4x4 Paid Member Paid Member
    where have all the mk1 vr6s gone ?????
  16. Hotgolf
    Smelly Cornelly
    To the scrappy!
  17. nutter4x4 Paid Member Paid Member
    Not mine it's still floating about ;)
  18. nutter4x4 Paid Member Paid Member
    bringing back the mk1 vr6`s !!! is there any still kicking about?
  19. DEX
    Dex Paid Member Paid Member
    Pics of Peanut?
  20. herbiethecamper New Member
    Gillingham
    Hi everyone I'm currently in the process of vr6ing my mk1 Golf Cabrio :-) not sure how to add pics
