The lambda would still be fused even if the lambda relay was removed anyway. Vw have removed the relay because it was unnecessary.
It is what we have been discussing. If you look at the diagram properly, where the lambda relay is. It shows some different dotted lines. The one that bypasses the relay is the later version meaning. The relay is not used because Vw changed it on later vehicles. It is not even present. What we were saying is. It is not needed because it complicates things just as Vw did. If you read the key on the right it explains what date the dotted lines are around from. Ie up to sept '94 or from oct '94 J208 no longer fitted I think you are over complicating it. The diagram clearly shows 2 alternative wiring options. They are not used at the same time. It is either one or the other.
I see. Consider it deleted. Once again thanks to all for all the time spent with me on this, replies in detail take time. I really hope I can report good news this weekend.
OH YES!!!!!! She`s alive Earthed 87 from the relay Earthed the black/brown from pin 28 Still wouldnt start!!!!!!!!!! Then I remembered the hidden switch for the main pump and switched it on It fired on the button no rattles no fuss. The oil light flashes and the top end was noisy so I assumed low oil pressure. I knew the senders can be dodgy so I got two from GSF. Made no difference so I thought sod it, I`m sure its not oil pressure but an issue with sender compatibility. Added coolant and started it up (no rattles) and it ran fine and after a minute or two the top end quietened down completely with minor normal noise and the injectors clicking fine. Ran it for the best part opf an hour, it stays cool and revs freely but after revving it it idles fast. Pinch the pipe from the cone filter to the ISV and it calms down and ticks over like a sewing machine with no movement at all so I assume its an issue with the ISV?? Am I being naive with regard to the oil light/buzzer as I had issues with it with the 1.8 driver engine that was in it previously? Thanks again to one and all for the advice and help Thanks Rubjonny for the loom - we got there in the end. You only need to remember that (certainly on a Mk1) the Lambda/injector feed relay needs earthing as does Pin 28 - all else is spot on.
Well done. !! Got there in the end. The oil pressure will be low after the engine has not been run fir a while. You should really turn it over for a while to get pressure up a extinguish the light before starting. When my engine first started the top end rattled for what seemed like ages until it quietened. The isv probably needs cleaning with some petrol or carb cleaner to get idle better.
Thanks. The oil light went out when I first pressurised it - before starting - it then flashed when I was turning it over for a while so I assumed it was sensing low pressure however it stays on so I dont know if its the problem I had with the light/buzzer when I had the driver engine in it - and I used to thrash the pants of that one. It might be low pressure but the fact that the lifters are pressurised and the copious amount of oil at the top end (which requires high pressure compared to the bottom end) suggests it might not be. I have heard that the buzzer/light in a Mk1 can be troublesome. What it does regarding idle is when I rev it it stays high and then after a few seconds it drops and hunts a little and then settles down. If you pinch almost closed the hose from the cone filter it settles down to a nice rock steady idle. Would the fact that it has a cone filter reduce the vacuum to the ISV?
yay! the lambda relay was fine how i wired it, its just i put stuff on the output of the relay that I shouldn't have. if it was just the lambda heater then it would have been ok! but from now on the looms i make will have the relay filed under B for Bin where the isv is will have no effect on the isv, on my mates abf we just had the isv open to air with its own mini cone filter on as the airbox didn't have a connection for it. whats that 2 pin plug hanging there? is it the idle switch plug? also make sure the throttle is closing all the way to the stop. it could just be the isv is dead, took 4 isvs on mine before i found a working one
FYI, my inlet temps were much much higher when I had my airfilter in the same location as yours. I get much lower inlet temps when the airfilter is just bolted on at the end of the OE inlet pipe and ends up no further than where your tensioner for the alternator is. Gurds
Hi John I say leave the relay as it is supplying the Lambda sensor and injectors which if they short can pull a lot of current. It was only the two earths you need to change. I have cleaned the ISV and it visibly clicks open and closed when the ignition is on or off but doesnt buzz. The factory stated resistance via the contacts is correct. How does it work exactly and what does it tell the ECU?
Hi Gurds Thats interesting. I have thought about it a bit and have a small duct in the grille that will deflect air to it but ultimately will run a hose from the offside spotlight in the grille or shroud the filter Thanks for the suggestions - keep them coming.
with the lambda relay the wiring to it was fine and as per factory The problem was I wired the injectors to the lambda relay, because I assumed it was on with the ignition or the fuel pump relay. but it turns out this is not the case, the ecu controls the lambda relay differently which is why we had this problem. If i had run the injectors direct to an FPR output everything would have been fine Later ABF ECU do away with the lambda relay and instead run it direct from a FPR output, so for whatever reason VW decided the lambda relay was no longer required this is why I'm thinking from now on I'll just bin it to save a bit of complexity, and also 1 less thing to squeeze thru the hole in the bulkhead the isv has an ignition live feed direct from the fusebox to the black wire, the other wire runs to the ecu which is a pulsed signal and is how the ecu controls the idle. as i say, is that plug sat on the rocker cover for the idle switch? it may explain why its idling high if so? oh and I found that there is a reset basic settings option in vag-com, this might help you. its a few posts down in the vag-com abf label thread: http://www.clubgti.co.uk/forum/showthread.php?t=199583
`kin `eck that looks complicated. The plug is the right one (I believe white and black) and it splits out out of the injector plug wiring so has to be the one. Also checked it back to the ECU. The ISV clicks when the ignition is on and a piston (or something) moves back from the inlet that goes to the air filter. It clicks off when the ignition is off and the plunger returns. I believe inside is a stepper motor so assume this controls the position of the plug but I still dont see how it controls the idle as it doesnt directly affect the main air inlet via throttle body so unless it enriches or reduces the amount of fuel I dont see what it does or how it works as it only allows air to bypass the throttle body for some reason which will fool the ECU by weakening the mixture surely?
the isv should buzz rather than click, the ecu sends a pulsed signal to it so the isv opens & shuts at different speeds to regulate the idle. at least i think thats how it works it may be its buzzing but so quietly you cant hear, and the valve is moving so fast you cant see it?
Great to hear it's running now! I'd suggest fitting a proper oil pressure gauge, after all your hard work on the conversion. With the ISV you should be able to feel it vibrate, even if you can't hear it. Try swapping a known good one from another car if you can (mk2 golf digi is the same ISV as early ABF I think), or soak it in petrol/paraffin, but NOT carb/brake cleaner solvent.
The isv bypasses the throttle body, because on idle the throttle is closed.. It regulates the amount of air needed for idle yeah?that's how I figure my kjet 1 works anyway...
Cheers Mike I think I will fit one. I will be surprised if its low pressure but you never know It could be that I have the two sensors wired the wrong way. I soaked it in petrol and cleaned it out with electrical contact cleaner. It clicks but does not vibrate.
Hi I put the crankcase ventilation valve on as the hose was open ended and for some reason it seems to be ok although it still takes a second or two to drop from about 1500rpm I replaced the vacuum hose from the FPR to manifold but it is still a bit sluggish in picking up from idle in that there is s slight hesitation - is this normal as I thought the manifold vacuum raises the fuel pressure briefly? I snuck it out on the road and gave it some beans...................................... Superb, what a difference over the old 1.8 8v Driver engine. Pulls like a train, bit of torque steer and a very very almost indiscernible gearbox whine but its fantastic fun. My son had a couple of Mk1`s and this one was a project he bought but never went through with and he hasnt been in a Mk1 for a couple of years - he absolutely loved it. Few more bits and bobs to do and then some track time. Thanks one and all for the advice and encouragment, what a great forum this is.
