MK1 Zender Monologue...
Discussion in 'Mk1' started by Zender Z20, Nov 28, 2021.
  1. Zender Z20
    Got the loom out of its box as promised... Fook!
    Have a feeling I'm going to know a lot more about electrics by the time this is done.
    Old immobiliser (it worked when the car last ran 15+ years ago) was actually very straight forward to remove, basically boiled down to the two heavy wires I've zoomed in on being spliced into, everything else was on spades.
    I'm guessing they're to do with the starter / ignition maybe?
  2. Zender Z20
    ... and the cam cover plates turned up today, wasn't expecting them for another week.
  3. Cressa Paid Member Paid Member
    Have you just removed the immobiliser? Plate looks great
    I checked my mk2 and the data sticker in the car has EN, but not on the sevice sticker
  4. Zender Z20
    Took it out yesterday... after laying the loom out on the floor and taking a proper look at things it was pretty obvious how it'd been installed / what'd been cut into.
    Turned out to not be that much, just simple 1990's tech. I suppose.
  5. Zender Z20
    Cam cover back today... if you hadn't seen it before the SCHRICK script was milled down (to 2.5mm from 5.0mm) you'd probably think that's how it was intended to be.
    The GTiE plate is 2.0mm, so with the 0.5mm of the high temp. adhesive tape it'll sit flush with the untouched surrounding fins.
    Tested out the tape over the week-end on some off-cuts of aluminium, it's to be applied after a warming up and properly cures in 24hrs... they were stuck like sh*t to a blanket, could barely get the pieces apart again!
  6. Zender Z20
    Forgot to mention getting the flywheel back yesterday too.
    I suspect it's a MK2 item that one of the previous owner seems to have 'upgraded' to.
    Was at pains to tell him I wasn't looking anything dramatic, the car's not going to be raced or rallied and it was more about adding the work to the list of period modifications being done than anything else... shallow, I know!
    It was 5.1kg originally, a weight that seems to be borne out as standard on other forum posts.
    It's now 0.75kg lighter at 4.35kg, so not very much by the amounts others are getting off.
    Apparently it was just a bit of the rim and most of the raised detail on the outer face and that's it.
    Interesting that the logo's still there, didn't pay it much heed before, but that's SACHS, they must've made them for VW?
  7. Zender Z20
    This is a blatant (unpaid!) plug for 'Sayner Works'...
    Google him, he fabricates A1 Golf / Scirocco chassis stuff.
    Liked the look of his upper strut braces, but unfortunately he doesn't currently do them for standard engine / unmodified bays like mine, the postion of the original expansion tank gets in the way, but his front sub frames are a direct fit.
    It's a work of art and a millimeter perfect fit, the workmanship is exceptional, as is the finish... borderline criminal to hide it away under the car.
    erreesse and Cressa like this.
  8. Zender Z20
  9. Zender Z20
    Until I'd read the article above, never gave much thought as to when the RE1900 was introduced by GTi-Engineering.
    Got me looking back to see if it could be narrowed down to more than just the year, 1986.
    The engine Craig sent is (uniquely) marked 86.06.01 and if I've understood correctly that number is made up of the year/month and sequential order number for that month... so in my case that'd be the 1st order taken in June 1986.
    The order date isn't the same as the actual conversion date, which will be later, and both are marked on the plaque in later cars.
    Some of the images of plaques found on-line show just a short space of time between these dates (conversions were advertised as only taking days if on an exchange basis) and others can be quite a bit longer, I'm guessing it probably depended on their order books and how long it took them to work their way around to you.
    Anyhow, got me thinking 86.06.01 must be near the beginning of RE1900 conversions.
    Info's scant, but so far the earliest reference I've found is an advert in the April 1986 ' issue of Car' magazine where it's flagged as being 'New'.
    The April 1986 price is £1475, if you run that through this inflation calculator that equates to £4218 in todays money!
    https://www.bankofengland.co.uk/monetary-policy/inflation/inflation-calculator
  10. Zender Z20
    Mentioned away back at the start of the thread about one of the cars that influenced me the most was featured in the June 1983 Hot Car magazine.
    At the end of the feature it ran through all the modifications / additions GTiE did to that particular car.
    Granted it had the more expensive RE2000 engine and leather interior than I'm planning, but the remainder is more or less the same.
    Total price in 1983... £15130.81 (just over £49250.00 today).
    To give that some context they say the equivalent bog standard 1.8 GTI they tested the Z20 against had a list price of £7046.43 (just over £22900.00 today).
  11. Zender Z20
    A follow on from a couple of earlier posts... first being the adaptation done to a basic control pressure regulator and the second the getting of an enhanced vacuum version.
    The basic adaptation done below is just as before for that part of the enhanced regulator, each is more or less the same in that regard, but what's now included is an additional adaptation to allow for the adjustment of the enhanced regulators full vacuum aspect.
    Lots of pics, most are self explanatory or explained in more detail in the earlier post.
    Have tried to high-light the full vacuum adjuster, found beneath the brass cover.
    Went to the extra bother of trying to make it as completely sealed as it originally would've been.
    Now that the hex adjuster is exposed you'll possibly see there's a channel that runs up its center, taking you to the middle portion of the casing.
    You're seeing the regulator post clean up, you'll have to believe me when I say these get very dirty and it'd be inevitable moisture / grim etc. would enter the regulator via the now open brass cap if you didn't close things up properly again.
    I've just mocked up the final images, I'm still waiting for new 'O' rings for the fuel cell.
    Usefully the old 'O' ring perfectly fits over the now open brass cap, that and the white plastic replacement / black bung do the job instead.
    You just have to pull out the bung now, when wanting to adjust the regulator, takes a standard 4mm allen key.
    Can you guess what the white cap is / was?
    The discoloured gasket affair, mine was spot on and held vacuum perfectly.
    They do seem to fail though, but there's kits out there to replace them, that however seems to involve drilling out the 4x aluminium studs and replacing the metal cups / gasket before re-fixing with nuts and screws (supplied in the kits).
  12. Zender Z20
    All reassembled.
    If the vacuum diaphragm doesn't need replacing, it's really only the cost of a fuel cell 'o' ring and some 'o' ring cord plus a nut / bolt / washer.
    I've intentionally left the pin (that's now with an adjusting nut) and the fuel cell proud of where they'll likely ultimately be set, that'll need doing once the engine's up and running and the pressures can be read.
  13. Zender Z20
    Flogged a few things on eBay, also been watching the pennies and have finally been able to push the boat out and get a rollover jig.
    Don't see me needing it again when this is all over, so plan is to move it on when the time comes and recoup as much of the outlay as possible.
    So then, it's been a long time coming but onto the next big learning curve... welding.
    Did a pretty comprehensive session of night classes about two years ago, so not exactly starting from scratch, still be interesting to see how much I remember!
  14. Cressa Paid Member Paid Member
    That is impressive and great garage space. Good luck with the work. Back in 97 my mate helped me with my mk1 by doing a mass of welding for me. There wasn't much it didn't need replacing
    Zender Z20 likes this.
  15. Zender Z20
    A little free time this PM... ummed and ahhed for about an hour, then looking at things from left, right and center before finally getting the courage to fire up the grinder.
    From little acorns and all that... but that's not the point, it was more about getting me into the mindset!
    It was only the one side that was a little frilly / perforated below, the other's 100% and that's the intact one you see in the images / what I was aiming to replicate.
    Soooo much wax in there, it was streaming out with the heat of the cutting disc, someone'll definitely have to be on fire duty when the welding starts.
  16. Zender Z20
    It's as well I've some spare time, this is obviously going to take a while.
    The below was a couple of hours work for me and that's just making up the repair bits... there's more bare metal prep. and the welding yet!
    Little steps.
  17. Zender Z20
    Nearly five months to the day since the above post!
    Not much has changed unfortunately... nobody's fault but my own, times precious and simply chose to spend it elsewhere.
    As a partial fix, managed to get myself and my daughter back onto the same welding night class I did with her brother back in late 2021.
    If I thought he was a natural, you want to see her work... seriously (and I'm genuinely being serious) thinking of letting her do the MK1!
    They run a machine shop night class as well, trouble is it's the same night as the welding, but fully intend to get on it next year.
    And to the point of the post - picked up this VW tool (Hazet 3070) a few years ago, along with some others.
    I now know it's for helping with refitting cylinder heads, the pins (you just need the two) screw into the block and act as centering guides.
    Once you've things partly done up they're removed... the rod end / center of the pins are reverse threaded.
    This rod just came with the one pin and unfortunately it's to the larger M12 of diesel engine head bolts.
    Enter the machine shop course instructor... he very kindly cut down two old petrol engine M11 head bolts for me.
    I'm nearly sure I've read or seen something showing small pressed in pins on some blocks or heads that do the same thing?
    Can only say that the MK2s PB (used 11mm hardwood dowel that time), the MK1s original DX, and its intended replacement EV don't have them.
  18. John Bird Paid Member Paid Member
    Just finished reading your thread, I had bought a damaged mk2 with Turbo wheels in about 1990, only one wheel survived unscathed, which I lent to someone as a test fit and never got back! May still have the remaining centres in the old shed at my mums, I’ll let you know if so, but I don’t see me being there and digging into it until spring, feel free to remind me:thumbup:
  19. Zender Z20
    Spot on, thanks... can never have too much Zender stuff!
  20. John Bird Paid Member Paid Member
    I just wish I still had the wheels, can’t afford another set nowadays with 2 children! Here is the car before I got it damaged, German special order in Lhasa IMG_3286.jpeg
