Mk2 16v coolant sensors
Discussion in 'Engines' started by Blackie36, Jul 28, 2018.
  1. Blackie36 New Member
    Hi,Ive replaced the 3 coolant sensors on the bulk head and only got coolant coming from 2 of them does that mean there is a blockage?
    Thanks
    that is correct, 2 of the holes are cut into a coolant channel, and one is not :)
  3. Blackie36 New Member
    Thanks again for your help much appreciated
  4. Blackie36 New Member
    The one that’s not cut out to the coolant does that sensor go to the ecu?
  5. rubjonny
    I believe the blind hole is for the isv controller sensor, other 2 are ecu and clocks? probably doesnt really make a great deal of difference
  6. Blackie36 New Member
    Cheers mate,Do you know where I can buy the sensors as I’ve tried GSF and Vw heritage and can’t see them?
  7. rubjonny
  8. Blackie36 New Member
    Yeah I’ve seen that style but only one of my connections are like that the others are a straight spade connection
  9. rubjonny
    Both styles will work either way, just for the button style you got to pop the spade out of the plastic housing
  10. Blackie36 New Member
    awrite cool cheers for that mate
