I came across on the site a picture with labels for all the connections to the metering head for a mk2 golf 16v, (late model). I have tried loads of searches but i just can't find it again does anyone know where it's located?
Try this ... looking from the front of the car: Block on top of MH Rear left - cyl 3 Rear right - cyl 4 Front left - cyl 1 Front right - cyl 2 Centre top - WUR (larger connection) Below this `block` at the front of the MH is the inlet line from the pump / tank Below and to the right of the `block` from front to back are: WUR (smaller connection) Return to tank Cold Start Valve Make sense ?
I remember hearing that the injector lines can be connected in any order, not 100% sure that's correct though?
