MK2 16v not starting fueling problem
Discussion in 'K-Jetronic OEM injection' started by bavvm, May 11, 2021.
  1. bavvm New Member
    Hi so I have a 1988 16v MK2 golf, was parked up for several years. The car was started after a fuel change and then the fuel pump siezed up. So further I got the tank taken off, fully cleaned I then had the tank pump and filter changed, new fuel pump and fuel filter.
    I have noticed the fuel pump does prime but makes a clicking noise rather then buzzing noise and there's low pressure to the fuel line at the engine bay.
    Any recommendations?
    when you say you got a new pump was that the one under the car or the one in the tank?
