Mk2 16v standard front shock advice please?
Discussion in 'Chassis' started by Rustbuster, Jun 14, 2021.
  1. Rustbuster
    Hi volks,
    Struggling to get standard replacement front shocks for my ‘91 valver. Part number on ETKA is 191 413 031 K. Called local dealer and familiar old story, this part is now obsolete. I just want to check, when I look at replacements I’m looking for a gas shock, right? Thanks.
  2. Savagesam
    Bilstein upgrade time!
    Rustbuster likes this.
  3. Tristan
    What he said.
    Bilstein B4, basically a replacement for stock.
  4. dodgy
    Bilstein, very good.
  5. Rustbuster
    Cheers fellas, there’s a really descent Bilstein kit on eBay, all 4 shocks for £153. Can’t go wrong!
  6. Finite
    You might want to repaint the front spring seats. Mine started to weep orange out of the seat drain hole after 3K. The springs were new eibach with the sleeved ends.
  7. Rustbuster
    Wow 3k! Where they the Bilstein B4’s? Do you think the springs are too strong for the dampers causing the leak?
  8. PhilRyder
    I think he meant "orange" as in rust, hence painting the spring seats.
    Just to address your original question I think the originals are oil filled but the new billies are gas. Not to worry though, gas is better.
  9. GVK
    I was looking for Bilsteins for my mk5 and they have B4 on offer at Demon Tweeks - worth checking for your car.
  10. Finite
    Sorry yes Phil is correct. I'm not sure what it was in time maybe 1-2 years, but I know the mileage. I mentioned the springs being new and sleeved as it's unlikely they seeded the rust.
  11. GVK
  12. Rustbuster
    Ah right, got you. The B4’s are listed as gas but as I understand it they are still oil damped but pre-pressured with gas which just make them a bit stiffer in response to being shock loaded. Think that’s the difference between the 16V and other Golf’s as the 16V has part number 191413031K as opposed to same part number but with A or J.
  13. dodgy
  14. Rustbuster
    Yep, bought them from tdcautomotive on eBay (as in GVK’s link). Really nice looking kit and arrived next which was brilliant. Hopefully fit them tomorrow and then see how she rides. I previously replaced the rear shocks, but must have been twenty years ago. As for the fronts, I’m certain they’re original from factory which is amazing given the car handles fine and doesn’t bounce all over the road.
  15. Rustbuster
    Got the new shocks all fitted and they ride great. I found even though they’re stiffer (due to being new and the gas hasn’t escaped) it’s smoothed the ride, especially over bad bumps and ruts that no longer are transferred to the interior, so it’s all round a better drive. Only slight -ve is that the front rides slightly higher that it did on the old shocks. It used to look lowered but now looks factory again. Well pleased though, thanks to all for the input and advice on this thread.
  16. Tristan
    Rides better #becauseBilstein.
