MK2 - 2.8 24v VR6 - Engine Trial Fitted
Discussion in 'Members Gallery' started by Andy947, Apr 4, 2007.
  1. Seraph Banned
    -5129' 57N-07 29W
    [:s]
  2. Andy947 Forum Addict
    Scotland, Aberdeen
    Quck Update, got hold of a few bits and pieces
    New VR6 Clutch, Slave Cylinder and Engine and Gearbox mounts
    Heap of new bolts and stuff, Subframe, suspension and bumper bolts etc, plus a few random engine bolts etc - remarkably expensive for all they are :laugh:
    Got the VR6 flywheel fitted with new bolts
    Fitted up the Gearbox. You can see the New VR6 cooling/thermostat flanges fitted to the 24v head aswell - makes the cooling system plug and play with Corrado VR6 Hoses
    And a shot of the VR6 rear engine mount bolted up to the engine
    Hopefully get the Garage/Back garden sorted so i can start thinking about getting the MK2 stripped down. :v:
  3. GVK
    Good idea with the 12v 'stat housing etc, it's nice it fits the 24v head!
    Don't make the same mistake I did and pay good money for a Corrado VR6 rad and fans off eBay (I've not forgotten about it yet Bobby!) only to find the fans broken and the rad leaked when we filled it with coolant.. ended up using a Seat rad tucked under the slam panel with mk3 VR hoses - neater.
    Guess you'll have to shorten the rear engine mount as per 'normal' mk2 VR6 swap?
  4. Andy947 Forum Addict
    Scotland, Aberdeen
    I would imagine so, will trial fit it on the mounts as they are and adjust as required. I have a set of fans to go with the rad, off the toledo, Corrado VR6 sopec aswell, they'll need a new plastic support piece (about 15 from vw i think) might use em, might whack a slimline infront to keep it neat, see how it goes.
  5. GVK
    Used 2 x 10" slimline fans on mine, behind the rad, quite a bit of room still.
  6. cocobay63 Forum Member
    Truly Awsome Build, good Luck with it,
  7. prof Forum Addict
    Suffragette City
    now buy 2x Ko3 turbos off ebay and bolt them on the manifold flanges for a laugh
  8. mk1steve Forum Member
    swindon
    do it [:D]
  9. Seraph Banned
    -5129' 57N-07 29W
    i believe that would make it a 24v version of the old rs4(b5) engine!
  10. mk1steve Forum Member
    swindon
    apart from the rs4 is a v6 not a vr6 as this is
  11. Andy947 Forum Addict
    Scotland, Aberdeen
    Not massive progress, but slowly getting there
    MK3 VR6 front engine mount bracket on the 24v block, will require a small spacer on the top left bolt.
    Old 8v engine removed
    Empty MK2 engine bay, needs a damn good clean up. . . .
  12. Andy947 Forum Addict
    Scotland, Aberdeen
    Looks quite at home in there [8D]
    All mounts as standard, rear mount will need the 10mm chop, hopefully gain some needed bonnet clearance (just catches the top of the cam cover) :lol:
    Plenty room other side and front though :thumbup:
    Sump hangs pretty low. . . .
  13. MUSH Forum Member
    cant remember....?
    [:^(] bloody hell that is low!!!
    Looking good tho mate, liking this thread very much.:)
  14. GVK
    As you say, shorten the rear mount and it'll sit nice 'n' level - look forward to seing the progress on it.
  15. Andy947 Forum Addict
    Scotland, Aberdeen
    Will get the Stick shift removed tonight and will throw on the downpipe i got from PHAT, see how it fits and whats required to make it work.
    Where is the best place to get some exhaust tube and parts, need a 2 into 1 collector and some straight pipe to make up a piece from the downpipe to the Jetex ssystem. . . . ?
  16. thegolfman Forum Member
    Northampton, ENGLAND!
    Looking good mate... cant wait to see the finished product :)
  17. Dub20vt Forum Member
    Somerset
    andy jetex do universal parts, i'm sure they'd have something suitable.
  18. prof Forum Addict
    Suffragette City
    you getting the loom from Phat/Daz's mate Andy?
  19. monza 16v Forum Member
    Saor Alba
    Coming along mate, can't beat that noise [8D]
  20. Andy947 Forum Addict
    Scotland, Aberdeen
    I think so, Phatboy is waiting on a loom / some parts to get it modified :thumbup:
