Mk2 ABF DTH bodies, filter and rad clearance
Discussion in 'Throttle bodies & non-OEM ECUs' started by Neil_Ireland, Dec 16, 2020.
  1. Neil_Ireland Forum Member
    Hi all,
    I have a jenvey dth kit, less filter setup.
    I’m wondering what people use for filters, I have sock filters but I won’t be using them, I’m looking for a filter box or large single filter.
    I contacted badger, they mentioned clearance issues around the rad, I thought there may be clearance issues with the centre grille spots.
    Is there a proven setup out there where I can keep the centre spots and use OE components for cooling?
    Thanks.
  2. Savagesam
    Paul elsey has Jenveys on his, I don’t know if it’s any help to you..
  3. Jon Olds Forum Junkie
    DTH Jenvey's on my Ibiza, same or very similar air filter. Had to chop the inner part of the bonnet to get it to close. While I was at it added a cold air scoop
    to feed the filter. ABF bottom end so already a tall lump
    Jon
