Mk2 Double door membrane?
Discussion in 'Mk2' started by smp1987, Oct 27, 2010.
  1. smp1987 Forum Member
    Smarden Kent
    Was thinking about this the other day and was wondering if it is possible to do
    My idea is to give my golf a bit more sound proofing and insulation in the front doors.
    Put the old style plastic sheet membrane on the door first to stop water ect that will keep it water tight and stop the door cards getting damp.
    Then put the new style foam membrane you get from GFS like in the mk3 over the top to act as sound proofing and insulation glue it over the top of the plastic membrane?
    Old style membrane that in my mk2 atm
    Then this membrane on top (google Pic)
    Would this work and give the doors a bit more insulation and sound proofing? as in my white mk2 you get a lot of road noise through the doors. It works in my head :lol:
    it'll work, but no reason to have the plastic stuff underneath if you fit the mk3 stuff it does the same job but better
  3. 3Tripnip New Member
    What is this 'mk3 stuff' that you speak of? :p What parts off the MK3 allow you to delete the plastic membrane stuff and still have a vapor barrier?
    its like a thin foam material rather than plastic sheet. if you've ever laid down laminate flooring its similar to the stuff you're supposed to put underneath it. cos its foamy it offers a little extra sound insulation. you cant get the thin sheet no more, order sheet for the mk2 golfy and the mk3 stuff is what you'll get
  5. 3Tripnip New Member
    Ah, gotcha. Thanks for the info! :thumbup:
  6. smp1987 Forum Member
    Smarden Kent
    i got some door membranes like the old style off ebay :thumbup: only reason i ask is that the foamy stuff on its owns went a bit soggy in the golf so i had to replace it
  7. rubjonny
    no reason why you cant have both :thumbup:
    i use plastic dust sheets, got tons o the stuff for 10, done 5 cars with it now still got a little bit left :lol:
  8. smp1987 Forum Member
    Smarden Kent
    :thumbup: mine were 4 for 4 sheets posted :lol:
  9. TheSecondComing Forum Addict
    I use flashing tape meant for yer roof - sticks like anything and you can put on a couple of layers for sound deadening.
    edit - Marley, that's who make the tape. Overlap it ( do it from the top down in strips), and make sure your door drain holes are clear...
  10. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Visqueen and gaffer tape here. Never fails. :thumbup:
  11. Sam.
    Sam. Forum Member
    I made moulded plastic panels for mine, wanted to be sure no water got in and the door was airtight :lol:
  12. kipvr Forum Member
    Pics? How did you mould them?
  13. Gaz37 The Grouch. Paid Member
    ZZ plural 9 alpha
    Heavy duty rubble sacks FTW, what's all this nonesense about making Mk2s quieter, if you want quiet buy a Lexus:lol:
  14. JWYATT Forum Member
    South Coast
    I've just been looking for something like this i get looking for some extra layers ,
    Jo :thumbup:
