Hi every one iv decided after a bit of time I'm going to go down the 2L conversion I just need a little bit of info. Iv got my AGG engine and iv had the pistons cleaned with new rings and big end bearings put in. I'm just stuck on the gear box and clutch setup can I use my 1991 mk2 8v digi flywheel and do I need to put a updated / stage 1 clutch in ? Any help would be greatly appreciated. Thanks mark
hi just done my 2L conversion using a AWG engine and the following parts for a PB, gearbox, flywheel and clutch (new kit).
