Mk2 golf a pillar gutters
Discussion in 'Styling, Trim and Bodywork' started by Wygolf, Nov 30, 2019.
  1. Wygolf New Member
    This is possibly in the wrong spot so apologies if it is
    after having a new scuttle I’ve come to re install the gutters on my mk2, got the roof/ above the doors all clipped in but can’t seem to get it to clip onto any of the clips down the a pillars, any recommendations on the tool to use and how to do it?Used a blunt chisel to tap the rest in place with a small hammer
    Any help really appreciated!
  2. Richard Gilberd Forum Member
    hmmm, i think i started at the A-pillars with mine and i used all new clips, it could be that you're not sitting far enough back on the A-pillar, i know that they are a pita to get on and off!
  3. Wygolf New Member
    Im using all new clips but still no luck, I’ll give it another go, how did you go about tapping them in under the lip? Bend the rubber back with the tool?
  4. Richard Gilberd Forum Member
    if i remember right first i went under the lip and then with a rubber hammer and a block tapped them home, unfortunately mine at the back are a little bent up, use a little wd40 on the rubber it makes everything easier
  5. Wygolf New Member
    Thanks for the info mate I’ll give it another go
    Start at the front and work your way back is my tip, I've never used any kind of tool either just my bare hands
  7. Phil_j New Member
    Kendal cumbria
    Marking where the clips are with masking tape helps, too!
