Hi I have a 1991 mk2 golf gti and I've been having display problems the LCD has been replaced twice and it's always the same fault half of the display is missing does anyone know what else I can look at to find out what's causing this I'm out of ideas
when replacing the screen did you make sure its suitable for a CE2 MFA cluster? as CE1 and non-GTI screens are not quite the same. If so then I'd say the main circuit board is to blame
are they motormeter? possibly the MM lcd is different to the more common VDO type. I might be able to fix them up for you as I have some spare 8v boards if you want to send all the bits to me?
