JTech Performance Parts VW Golf Mk2 Billet Front Engine Mount. (Not VR6/R32 conversion compatable). Replace that worn, performance limiting standard rubber/fluid filled engine mount with this high quality, machined from billet aluminium solid front mount. Despite being a totally solid mount the extra vibration is very minimal, still perfectly suitable for a daily driver, or your race car. Your OEM rubber/fluid mount allows excessive engine and gearbox movement when worn. The solid mount will keep your engine and gearbox solidly in place where it should be. Allowing power to be put to the ground more effectively. Gear change quality will be massively improved. Supplied with high tensile cap-head bolts, and washers. We recommend use of stud lock when assembling due to harmonics/vibrations potentially loosening the bolts 67.50 in Vat and Postage. Available on our Ebay shop! http://www.ebay.co.uk/itm/131598876776?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649#ht_329wt_1182
