mk2 radio slot gauge holder NEW PICS
Discussion in 'Electrical' started by steve r, Mar 12, 2004.
  1. damogti Forum Junkie
    Chichester - West Sussex
    :) thats better ;)
    I just feel a bit annoyed with my self really for going that high with the bidding, esp as i really havent got the cash for this sort of thing with inters being in a couple of weeks.
    35 is loads for an interior light, even if it is rare as hell to get hold of......
    Still, bit late now. Once i get it and fit it i'll be wondering what i was moaning about im sure.....
  2. damogti Forum Junkie
    [8(] thanks mate ;)
    Your really helping......
  3. jprocter Forum Member
    Antarctica
    :lol: i love to kick some1 when there down :lol:
  4. damogti Forum Junkie
    [8(] Thanks........... [:^(]
    :lol: ;) :lol:
  5. Mikey Forum Member
    These tinted interior lights are rare?? I got mine about 6 years back from a chap breaking a LHD German Golf, for the grand price of
    2 ;)
  6. jprocter Forum Member
    Antarctica
    Dont look Damo !!!! :lol: :lol:
  7. damogti Forum Junkie
  8. Jetta Forum Junkie
  9. steve r
    steve r Forum Member
    yep good quality copies,
    nice collection of gauges you've got there..
  10. GVK
    Got my VDO gauges this morning [:D] Just got to make up some brackets to fix the gauges to the din panel and hopefully pick up a cheap twin pole sender at Inters then I can fit them.
    Do I really need the relay that's part of the gauge loom, as far as I can see it's wired to the illumination and the oil gauge.. is it a buzzer too? [:s]
    Edited by: G_V_K
  11. Jetta Forum Junkie
    Nope, just wire the senders straight to the upside down T on the guages, for the twinpole pressure sender connect the gauage to the terminal marked G and the original wire for the oil pressure warning system to the terminal marked WK.
    Wire the +ve up to a red/black ignm sense wire and the ilumination to a grey/blue wire and the earth to a brown wire.
    I was quite lucky as I got my guages from a scrap yard that didnt know what they were worth, I got the oil pressure sender, oil temp sender, all three guages, and as much of the loom at either end as I could easily cut off for a fiver.
    Edited by: Jetta
  12. GVK
    Cheers Jetta :)
    I'll bin that relay then :thumbup:
    Oil temperature gauge,can I use the sender for the MFA ?
    Edited by: G_V_K
  13. mk1. Forum Junkie
    yes,or put 2 senders on a T piece so the mfa one works aswell,I find on mine they both give different readings? [:$]
  14. alby Forum Junkie
    Albania
    gary your pm box is full.
  15. GVK
    Most of my MFA is fecked anyway,, so I'm not worried about the Oil temp function either :lol:
    Will clear it out Al.. ;)
  16. Jetta Forum Junkie
    some said aes ago the MFA sender has a different temp range to the VDO guage one? also you dont need a T-piece as you can use it as a sump plug, though my sender off a d reg audi coupe, 1.8 4 cyl inj has a thing comming off the side fir the semp sener to go in to, if i can find a pic I'll post it up.
  17. PaulM Forum Member
    found this site for gauges and stuff. They've got some oil pressure senders aswell, about 16 + shipping.
    Would they be any good? I was thinking about getting part no. 360-006
    EGauges
  18. GVK
    Just got my dash stripped out ready to start wiring in the VDOs and it's started fecking raining (again) [:x]
  19. GVK
    In between rain showers,watching Days of Thunder and other Bank Holiday nonsense on TV , I've fitted my VDO's[:D]
    Took an ignition feed for the gauges from the park brake warning bulb holder, illumination from the heater control (works with dimmer) cut up an old 16v engine loom for some cable and terminal boots :lol: Just need a sender for the oil pressure (cheers Alby and GTIMM)
    I've taken the oil temp from the sender in the head (disconnected from MFA) but as some of you have mentioned, it gives the gauge false readings [:$]
    If the MFA is reading 98C the gauge is reading 120 + [xx(]
    I don't really want to use one of those sump plug senders as the oil is cooled by airflow over the sump and there's minimal flow down there, is there a sender that will screw into the head with the correct values to match the gauge?
    There's a blanking plug in the filter housing on the 9A as well... ;)
    Edited by: G_V_K
  20. Peter Forum Member
    Looking good Gary, I've got the same gauges fitted they light up a treat much nicer than the earlier ones. There great for peace of mind as you can quickly glance over the engines vital statistics :lol: I'm going to strip my main dials soon and paint the needles a matching orange. Mine regualry reads 120+ in the summer (using a sump plug sender)and the MFA rarely reads over 105. Have a search on the PVW forum I got loads of good info prior to fitting.
    Pete
    Edited by: Peter
