Do you have the repair sections for the drivers base bolster foam and material ? If not do you have any idea where I could buy them ? Thanks Bill
Hi There, We sadly can't get hold of the material to do this.. however, I partake in a bit of part time trimming, so might be able to advise. Your best bet is trying to source a donor seat.. either a passenger seat, or you should be able to use the material from a back seat too (in most cases there is enough - if not, you can join it right at the very front (or rear) and you'll hardly notice it once it has been sewn in. The foam, again, either source a passenger base - or the damaged foam can be cut out with an electric carving knife - a new block of similar density foam can be stuck in with spray glue - and then sculpt to shape with the carving knife. If you are close to Sussex and want me to take a look, drop me a PM (If you are in Kent - then My Dad is a Trimmer there I can pass you on his details) failing that contact a local coach trimmer to you and I'm sure they could help out with the foam repairs, and sewing in the new panels for you. Hope that helps Andy
There is always Parcel force if you get super stuck -could work off the foam and seat cover if needs be. Andy
Sorted now guys Bought a full set of seats so when my car hits the black stuff again the interior should be vgc
