Mk2 VR6 compression test results.
Discussion in 'VR5, VR6 & Wx' started by Funkmaster, Apr 12, 2016.
  1. Funkmaster Forum Member
    Hi all as the picture above, tested my brother in laws newly purchased MK2 VR today.
    The car feels so flat to drive, the first 2k rpm there is something there, but after that its all noise and no go.
    The above values are of course in PSI, but the difference in cylinders is throwing me as im sure they should all be around the same values.
  2. Toyotec
    Done with the throttle wide open?
    Test gauge is of good quality?
  3. Funkmaster Forum Member
    Ahem! Nope and a 40 Clarke tester from machinemart - so not the greatest but not the worse.
    Looks like another re-test is on the cards lol
    Im guessing the flat feeling is a sensor issue, perhaps maf, but id like to get a compression test done just to understand what sort of condition the motor is in.
  4. Toyotec
    You would need to scan ideally.
    Carry out the compression test.
    If it is 'flat' as described, and the engine is later coil pack version, one root cause is a dead cam sensor. You will need to scan it though.
    Funkmaster likes this.
  5. 1.8T_mk2
    1.8T_mk2 Paid Member Paid Member
    Hertfordshire
    Ideal test conditions are;
    engine oil temp min of 30 degrees
    fuel injectors / fuel pump disconnected
    all plugs removed
    throttle wide open
    battery on charge
    crank for the same period eg. 10 turns
    Oil the bores
    repeat test. If readings improve significantly compression rings are suspect.
    Compression pressure:
    New: 10...13 bar 145psi .... 188psi
    Wear limit: 7.5 bar 108 psi
    Permissible difference between all cylinders: 3 bar 43psi
    Your readings look ok :thumbup:
  6. Funkmaster Forum Member
    As usual. Super helpful! I genuinely love this place :)
