today i have finaly put me emgine in me mk2 but came across a small problem the engine is sitting to hight for the bonet to shut. i have use the mk3 rear engine bed with the mk2 front engine bed. has any 1 got any ideas what bits i can use so it sitts down a bit???
You need to cut down the front mount the metal that bolts to the engine/box, to get some clearance. Or get hold of a corrado front crossmember
I am lead to believe so yes,I should hope so anyway as I will find out in a couple of weeks. When i fit my mates vr
ill go hunting for 1 tomorrow i need a rad anyhow thanks for your help, ill let you know now if it works when i fine 1
