mk2 vw caddy pick up lucas pump problem
Discussion in 'Diesel' started by TrackCab16v, May 13, 2013.
  1. TrackCab16v Forum Member
    hi guys got a mk2 caddy pick up , cross over model with skoda, its a sdi 1.9 vw engine , with a lucas diesel pump . does any one know the correct trouble shooting procedure for this type of pump , it seems half electrical and half mechanical , just cannot get it to draw the fuel through it, help appreciated on this one , I need to know what controls what on it , not much info on this one out ther cheers paul
  2. Brookster
    do you have vacom ? if the throttle peddle sensor working ? is the fuel solenoid working ?
    if the pumps done over 100k miles speak to Diesel Bob
    http://www.dieselbob.co.uk/
    probably needs a rebuild if the seal are gone ?
    or you could do a conversion to M-TDI using a Landrover 300TDI Pump and run on veg oil :thumbup:
  3. TrackCab16v Forum Member
    cheers brooky all points taken on board , gona have another crack at it over weekend
  4. TrackCab16v Forum Member
    got this sorted , what a pain
    original pump was knackered , just not pumping fuel
    rebuilt bottom end just didn't work , would not fire. then replacement pump was immobilized , , all hitting you at once
    so her we go ,
    changed bottom end , got engine to fire with easystart or fuel pumped in direct
    .fitted new pump, no fuel no go , immobilizer issue,
    so stripped out emobilizer from original pump , refitted it to new pump
    refitted pump , happy days , dragged fuel through and it went , ,
    so that was engine engine and box out 3 times
    head of and changed 3 times , trouble shooting ,
    various pumps on and off at least 6 times , embaressed to say any more ,[:x]
    so hears the spec
    1.9 na diesel ,
    mild gas flow and ported head
    lightened and balanced flywheel ,
    cable adjusted pulling full throttle ,
    sounds and feels very responsive for a na diesel ,
    pulls 105 mph with the wheels off the ground , according to the speedo ,
    gona ask my youngest son to get a vid clip of it ,
    worked out how to make it rev higher but I can.t be bothered to take the pump off it again.
    all in all its a piece of crap and I can,t wait to get rid of it , but i couldn,t let it beat me .
    and now the lighting circuit don,t work , [:x][:x][:x]
    but any how big thanks to crispy , every bit of info helps , :thumbup:
