MK3 16v GTi Downpipe / Front pipe change
Discussion in 'Mk3' started by Boost16v, Jun 7, 2010.
  1. Boost16v Forum Member
    Warwick
    Hi Guys!
    Got an MOT due in a couple of weeks and have a leak on the exhaust. Someone in the past has welded the cat to the downpipe and the cat needs replacing. Is it possible to remove the downpipe without lowering the front sub frame?
    I've got a friend at a garage who will attempt the removal and fit the new one. He just wants to know how much of a job it is...
    Thanks in anticipation!!!
    grind the cat off and you shouldn't need to drop subframe to replace the downpipe, it'll come out from above if not bellow. I fitted a manifold with downpipe attached from above with the engine in, it was a bit of a squeeze but I got it in there eventually!
  3. Boost16v Forum Member
    Warwick
    Thanks for the info John. I'll give it my best shot this weekend all being well! :)
  4. tshirt2k
    tshirt2k Forum Junkie
    Herts
    Can be taken out from above with inlet manifold removed.
