Mk3 8v into Mk2 1.3
Discussion in '8-valve' started by PhilRyder, Jul 31, 2021.
  1. rubjonny
    yes white plug for lighter, blue plug goes into the fusebox. if you wanted you could strip out the mk2 ciggy/radio/blower wiring from the blue plug then adapt and fit the mk3 one in its place ;)
  2. PhilRyder
    So bin Mk3 white plug.
    This is all I have left of the Mk3 blue plug. Is it needed or can I bin it? IMG_20210917_091803948.jpg
  3. rubjonny
    dont need it, thats for blower, radio, ciggy lighter connection to fusebox. i.e., you already have one ;)
    PhilRyder likes this.
  4. PhilRyder
    Brilliant, thank you John. I'm getting there slowly, wire by wire :lol:
  5. PhilRyder
    Hot diggety! Found the jumper block! :clap: I remember now, finding it on the floor of the car and popping back on the fusebox, what stroke of foresightedness :)
    Now everything is together and labelled up I shall list what goes where as far as I understand it now.
    From VAGCOM port
    red/white is live and splices into live of cigarette lighter
    brown is earth and splices into earth of cigarette lighter
    yellow and grey are connected to the same plug and go to the jumper block
    From Immobiliser box
    Thick black is earth and goes to a convenient bodywork earthing point
    Thin black is ignition live and is removed from green connector and put into a spare hole the back of Mk2 D plug on back of fuse box
    grey goes to jumper block
    grey/white connects to matching plug coming from the ECU
    Picture of jumper block and black pin out of green plug
    Now, one last question.
    What does the jumper block do? Is it supposed to have other wires going into it? Are all the pins connected and therefore linking the grey and yellow wires and the grey wire?
    yep all correct. if you look at your D plug you'll probably find a black wire with empty plug housing hanging out of it, the E plug pin will fit there.
    the jumper block is there to allow many different things that require diagnostics to plug into the same block and get a connection to the port, this way the looms are all removable. things like ABS and airbags
  7. PhilRyder
    Thanks, that's great.
    So are there any other wiring changes I need to make from this point?
  8. rubjonny
    nothing for the inside no, just crack on with engine loom ;)
  9. PhilRyder
    Do I need to make any changes to the engine loom or is it just a case of wrapping it and plugging it in to F, G1 and G2 now? (Are there already plugs in those ports that I will need to swap wires from on the Mk2?)
  10. rubjonny
    the next step once cleaned down is lay it out next to the old loom. transfer wiper wiring and bulkhead gromets over, add ignition loom. fiddle with the mk3 wire routing so it runs liek a factory mk2. the mk3 ecu loom goes thru hole on passenger side, ecu in middle. mk2 goes thru hole in middle, ecu driver side. with a bit of tweaking you can make it route like a mk2, but you end up with a fair bit of excess behind fusebox, which I trim off and re-terminate with new pins. you can try to loop it back on itself then tape
  11. rubjonny
    or you could put the ecu plug thru the mk2 wiper hole, and make some kind of bracket to hold ecu in the middle. if you have the mk3 bracket base it off that, or the basic way is velcro strips :lol: theres plenty of room under the wiper linkage
  12. PhilRyder
    Thanks John. Don't forget ours is a 1.3 carb. That must mean very little engine loomage to worry about?
  13. rubjonny
    yeah, you use the old one for reference on the routing thats all, plus you need wiper loom as mk3 one is too short plus ignition loom if you want to convert back to mk2 coil and spark module (optional)
  14. GVK
    cool swap , looking forwrd to the progress
  15. PhilRyder
    Work began in earnest today. Gearbox back on and cam belt and tensioner changed. One crank shaft pulley bolt wouldn't budge and eventually the socket head rounded off. Hammered a spline bit into the hole and thankfully that was enough to get it undone :thumbup: New set ordered.
    Front engine mount, that @dodgy gave us (thanks Mate ;) ), fitted although I did have to weld this bracket back on which supports a metal pipe of some description.
    Tomorrow we hope to get the old engine out.
  16. dodgy
    Glad it fitted, let's hope it lines up at the crossmember [:-B]
    Progress is what we like
  17. PhilRyder
    Just to give you an idea of what I am up against here, garage this morning.
    My driveway, no hope of rolling in and out!:cry:
    Front of car off, engine out.
    Subframe is also now off.
    Mk3 subframe going together having been cleaned and painted.
    Tomorrow is finish subframe, gear linkages, subframe back on and hopefully back on it's wheels :)
    erreesse and dodgy like this.
  18. PhilRyder
    Started stripping out Mk2 loom.
    What is this? Something to do with distributor?
  19. dodgy
    Ignition amplifier, like lucas dizzy has but not bolted to the side of the unit.
  20. PhilRyder
    Thank you. So it can be removed since I'm not using the Mk2 coil at the moment.
