mk3 convertible roof
Discussion in 'Mk3' started by nme motorsport, Aug 22, 2011.
  1. nme motorsport Forum Member
    i have just bought a mk3 golf convertible and i need to replace the roof how easy/hard is it to do as i have never done 1 any helpp would be great thanks
    have a look in my sig, i have 2 guides on how to do the roof. its slightly different depending on the age of car
  3. nme motorsport Forum Member
    l reg 1994 matey electric roof
  5. nme motorsport Forum Member
    i also need a wiring diagram for the electric roof switch as i have no constant live to the switch thanks
  7. customiz New Member
    i have also just bought a mk3 cabrio, same reg year, dont want to sound patronising, but if you didnt know, roof only works with key in the ignition but in the off position, and also i have just had to change my ignition switch as i kept to loosing my ignition live circuits. 20 min job!
  8. nme motorsport Forum Member
    thanks mate i know it doesnt work when engine running good shout though but i have to run a live to up and down wires when i want roof down from the rear lecky windows
  9. orangecruz Forum Member
    Poynton
  10. rubjonny
    see my sig:
    g3cabwindowadjusthood.pdf
    g3cabwindowadjustfront.pdf
    g3cabwindowadjustrear.pdf
  11. orangecruz Forum Member
    Poynton
    Thanks but when I click on the link it asks me so sign in
  12. rubjonny
    keep trying it should work, or create a google account
  13. orangecruz Forum Member
    Poynton
    I have logged in using my google acc. All that comes up are my docs. How do I get to yours.
  14. rubjonny
    sign out again then close all your pages and try again? i just tried it here and i got in fine!
  15. orangecruz Forum Member
    Poynton
    i have just tried on my pc instead of ipad or iphone and got streight in thaks mate
  16. Benja123 New Member
    Hi
    Does anyone know if you can pop a mk3 soft top and mechanism onto a mk3.5? Recently purchased a mk3.5 but softop has been slashed. Local repair specialist in Swansea said the bonded window on the 3.5 is a nightmare, as a result nearly double the price to replace. Can get a decent mk3 roof and all the bits etc, but wondering if its a straight swap.
    Any help would be appreciated. Thanks
  17. Anj
    Anj Paid Member Paid Member
    Probably too late now, but I have a very early mk3.5 but I have been told it has the roof from a mk3 which has the rubber seal rather than heat sealed. I have taken off the roof which had separated on the seam. I have a friend who was going to sew it up for me but found a replacement. It’s In pieces if any of it is any help to you?
