Hi all, Hoping Rubjonny will be able to answer this one, is there any difference between the looms for a 2E and an AGG engine, if there is, can they still be interchanged without trouble? Regards, Richy
yeah there is, and no they cant 2e/agg use slightly different management, so it'll only work if you swap over all the other gubbins that's different. Also AGG has a crank sensor where 2e does not, so you cant run a 2e on AGG management without fitting a crank trigger wheel of some kind, but you can run an AGG on 2e management if you do the above.
