How do you do it? That bloody leak i had wasnt the door seel!! I took my speaker out of the door card and the back is rusty! there is a rip in the plastic where could the water be coming in? what should i do? Any help would be great
window seal usually the bottom one that runs along the bottom of the window if the inside of the door is rusted. my car did that created puddels inside the car Edited by: Mk2 Jettagod
replace the door with a new one unless you can be assed to have the skin changed shouldnt come to that though man just check the seals you will see the gap between the window and the seal! my jetta is doing the same thing at the moment so while changine the seal am gonna tint the windows but need engine to run first am sick of driving the bosses micra e-reg piece of cr@p
Hopefully someone can help me again I have taken the door card off very easy! dunno how hard it will be to put it back on Anyway the plastic sheeting is ripped above the door speaker and the door speaker on the door card is wet and damp, there looks to be run marks on the door card from the top inline with the door speaker gap Can i take the plastic sheeting off? to see whats behind it??? What you reckon is causing the leek, the window seel?? Help please
Can i take the plastic sheeting off though? Cause it seems the water is coming inside the sheeting and not on the outside
'Door membranes' are surprisingly cheap from the main stealer,it's worth getting new ones and sealing them up with silicone or the like.
Yeah thats what they're called! Did you say yours were plastic? on mine they are a foam type material which probably works as a better sound deadner,and insulator.
Yeah i am gonna tape it up, yeah mine is like a thin piece of stretchy plastic sheet defiently not foam material. Would prefer to have foam type to cut down on sound
my doors (mk2) are done with flashing tape, they sound heavy when they close and to be honest are better than my membranes ever were, they havnt let a drop in and keep the roadnoise down!
Flashing tape?? whats that? Also should there be water coming in?? or is this normal and its just because of the rips in the membrane thats the problem?? I dont think there is much water just drips but over time and with the heavy rain it made a mess
