mk3 golf questions
Discussion in 'Mk3' started by Deon Corbett, Feb 26, 2020.
  1. Deon Corbett New Member
    Hey all, I recently bought a really tidy mk3 16v 2.0l 4 door GTI and I have thought about doing an engine swap. I was thinking something turbo or maybe a ls1 as that would also fit fairly easy.
    what have you guys done??
    otherwise with my stock engine what could I do?
    would it handle a turbo?
    Exhaust mods, tips, what have you done?
  2. Savagesam
    Just turbo the ABF, have a google. It’s not cheap sadly :(
    I’m sure others will chime in with some mega detail
  3. rubjonny
  4. Franko New Member
    Hi guys
    Need some help just changing the front shocks on my mk3.5 cabriolet but when assembling the new ones back and drop it of jack they seem to raise off the car a bit
    Not sure what’s wrong but it weren’t like that before
  5. Tristan
    Pics?
    if its all freshly put together often it'll sit a little higher. give it a bit and it will usually drop down
  7. Franko New Member
  8. Franko New Member
  9. Franko New Member
    Trying to put pictures up won’t let me
  10. rubjonny
    once you have a few more posts you can uplad direct to the forum, until thewn you could use 3rd party host and hotlink though that can be tricky
  11. Shivaan New Member
    Howzit guys need some help I have a vw AAG engine not sure if it's a 2.0 hopefully someone can help
  12. rubjonny
    Assume you meant AGG, if so thats later mk3 golf 2.0 8v yep
