Mk3 Gti ady 2.0i factory immob removal defeat
Discussion in 'Security' started by bazzagolfgti, Jul 19, 2012.
  1. bazzagolfgti Forum Member
    newark/nottingham
    Mk3 Gti ady factory immob removal defeat
    Having major probs with the immob on my 95 m reg Gti
    Just asking can the factory fitted immob be removed by vag com
    The immob keeps cutting in on start up untill I disconnect the ecu then reconnect
    Then it starts
    Please help
  2. jmsheahan CGTI Graphics Designer
    Wiltshire
    The immobilser can't be defeated using Vagcom but you can re-code the ECU to a different transponder and key chip if that is where the issue lies. Have you scanned the car with Vagcom for fault codes at all?
    If you want it properly defeated I had mine done by Stealth Racing a few weeks back - it was 85 plus the VAT. Spot on service.
  3. bazzagolfgti Forum Member
    newark/nottingham
    great thanks
    will get that done lol
    yah scan both the ecu and the immobiliser for codes to make sure it actually is the immobiliser. if it was the immobiliser, unplugging the ecu wouldnt help
  5. bazzagolfgti Forum Member
    newark/nottingham
    the code was a immob code
    but as soon as i unpluged the ecu left it for a min or so pluged back in it started
    scan the immobiliser next, this will tell you WHY its kicking in
  7. bazzagolfgti Forum Member
    newark/nottingham
    will book it in as only have a handheld scanner
    did it again this morning first time i started it cut out 2nd time it started ok
  8. rubjonny
    i would try another reader coil to start with from scrappy, mine did the same changed it and its been good as gold ever since. just make sure its same type as yours as later mk3, seat and polo use a slightly different immob box and the reader off one of those wont plug in
  9. bazzagolfgti Forum Member
    newark/nottingham
    The code that come up is 17978
    Just checking google as not got it in my book
  10. rubjonny
    thats the ecu code for start blocked by immobiliser, you need to scan the immobiliser itself the address is 25 if that helps?
  11. bazzagolfgti Forum Member
    newark/nottingham
    thank you will try and get it scaned later
