My AGG 8v currently has 288 brakes on it at the moment, what's available for upgrading now I'm running 17's?
Adey, You'll be able to keep same calipers. But will need to buy new caliper carriers off a 312mm setup and obviously 312 discs. When fitting two 6mm washers will be be required between the hub and caliper carrier to correct the offset
