mk3 ignition module/coil
Discussion in 'Electrical' started by firstgti, May 15, 2010.
  1. firstgti Forum Member
    Leeds .. West Yorkshire
    Ive been trying to find a wiring diagram on a mk3 golf ignition module/coil but cant seem to find 1 .... what i need to no is .. on the module/coil theres 3 prongs .. i need to no which 1 is + and - and what the third 1 is for .....
  2. tshirt2k
    tshirt2k Forum Junkie
    Herts
    3rd is to trigger the coil which is the middle pin on the plug. Use a multimeter to find +ve and -ve.
  3. firstgti Forum Member
    what do you mean when you say trigger the coil ..
  4. Stewy
    Stewy Paid Member Paid Member
    Midsomer Norton
    1 & Earth For checking Earth Resistance 0
    1 & 3 For checking Supply Voltage 11 v min
    2 & 3 For checking Signal
  5. Stewy
    Midsomer Norton
    TO THE ABOVE
    [​IMG] [​IMG]
    what he means is the 3rd wire is the trigger wire from the ecu which signals the coil to spark. black is +, brwon is - and the green/brown is the trigger wire. what engine code is it?
