Hi, I've just purchased new discs and pads for my '91 Golf GTI 16v. After removing the rear calipers, both seized?! I see the site offer MK4 rear caliper conversions. Will I get much benefit from this upgrade and will the existing discs and pads fit or will it require more new parts? Thanks Adam
They should go on with no probs the pads/disks are the same but you will need different flexi hoses because they have a banjo type fitting, goodridge do um, i think they are available from GSF, and are designed for this.
People use these for this reason as the standard items do seize. As said you will need some conversion hoses we do these 27.
