Is there a high and low or a single connector? On my loom I only have wires labeled for 'oil pressure' and 'oil level'. I'm using a Mk4 loom, Mk5 oil filter housing and I'm sure I fitted an extra sensor into a blank. Will try and get a picture tonight.
Seems I do have 2 on there. A grey original which is connected to the R32 loom and a blue one I added on: The 2 connections I have are labelled 'oil temp sender' and 'oil pressure switch' Any ideas?
you will need to bin the mk5 switch and swap the other mk2 one in there, chop plug off and crimp a spade on assuming you spliced the 2nd mk2 oil pressure wire to the T14 plug pin which feeds the mk5 pressure switch? if you want the oil temp sender to work for the MFA (im assuming thats what you meant by 'oil level') then you'll need a T piece you should have a white 1.8bar pressure switch, yellow wire to G2/10. 0.3 bar blue or brown with blue/black wire to g2/11, and a smaller white oil temp sensor for mfa, green/black wire to g2/1
