modifying the mk5 gti
Discussion in 'Mk5' started by Matt G, Oct 29, 2013.
  1. Matt G Forum Member
    How is it noisy? Would you say it's worth bothering with? Or more for peace if mind? Can they be lightened and balanced like the good old mk2's etc or is that not wise?
  2. gillm
    gillm ***** User
    If your gonna up the power more the 300hp then a proper clutch and flywheel is a must
  3. murph81 Forum Member
    I was reading a post by Badger5 on Seatcupra.net and it mentions RS4 injectors are the wrong spray pattern for a 4cylinder, shows a pic too!
  4. dUff
    dUff Administrator Admin
    Do you have a link for that, would be interested in checking that out
  5. murph81 Forum Member
  6. HPR
    HPR Administrator Admin
    Spray pattern is only one part of the bigger picture, even when they flow less ... D.I has its own sometimes strange needs.
    Loads high power TFSI engines use RS4 injectors in combination with an uprated HP fuel pump ( APR) and these were tested on a dyno
  7. murph81 Forum Member
    I would like to see back to back tests with just the injectors changed.
  8. Hi there.. Just a question about replacement air filters for my mk5 gti. Have seen that there are brands suck like k and n who have direct replacements.. Are these worth it or what is. Cheers
