Motorsport/rally Hydraulic Handbrake understanding?
Discussion in 'Track Prep & Tech' started by bigbenbird, Sep 11, 2014.
  1. bigbenbird Forum Member
    Alberta, Canada
    Hi guys
    I'm contemplating using a motorsport style handbrake in my project
    Mainly for launches and gymkhana type of use
    But how ever the I would still like to use the car on the queens highway!
    I understand that a traditional electro/mechanical hand brake is required to meet MOT requirements
    I'm guessing my questions are more about how to design/build/plumb a suitable system that will behave in normal use and allow me to misbehave on private land
    Ordinarily the brakes are paired diagonally, does this need to be changed to front and rear pairings?
    Could some kind of manual valve selection allow the system to be configured for the two styles of driving?
    What about front/rear brake balance adjustment?
    Any advice greatly received I am fully aware I maybe aiming for the impossible, or at least something prohibitively expensive
    BBB
  2. Terry47
    Terry47 Paid Member Paid Member
    Cornwall
    Hi there, to answer your questions it depends on how serious you are and how much you want (or need) to spend along with your skills.
    To fit a hydraulic handbrake you will need to split the front and rears into separate lines, get rid of the standard diagonal split. If you are still running the bias valve on the rear sub frame it should be okay but if not then you may have to introduce an adjustable bias valve into the rear line, to stop the rears locking up under heavy braking.
    Then it is just a case of plumbing the hydraulic cylinder into the rear line. Easy as they say. However you do have to be careful on how you operate the hydraulic cylinder. The most common form of installation is to mount the cylinder behind the handbrake and weld a lug on the handbrake to connect to the pushrod of the cylinder. This does work but I've found from prolonged use this does 'jack up' the self adjuster on the rear callipers and eventually starts to bind up the rear brakes. A quick solution to this is to loosen off the cables at the handbrake end so the cables are slack. The handbrake would still work the hydraulics and if that fails the cable would still operate the rear brakes. This also meets the MOT requirements as there is still a mechanical means operating the rear brakes. Once again I found this not to be 100% satisfactory so in the end I just unclipped the handbrake cables and plate from the bottom of the handbrake and just ran on the hydraulics, of course remembering to clip it again for road use. All parts for this conversion are widely available from many of the rallying outlets.
    Your next option would be to fit a separate upright handbrake which operates the hydraulics and leave the standard handbrake on its cables. Here is an image of my set up on the Rally Golf
    If you wish to go the 'whole hog' then a bias pedal box is the ultimate setup, and of course it comes with the additional cost. I would estimate that it would cost about 500 for this setup and that includes braided hoses throughout.
    Hope this info gives you some food for thought.
  3. bigbenbird Forum Member
    Alberta, Canada
    Thanks Terry
    Its easier than I thought then.......
    I already have a bias pedal box ready to go in.........
    So the change from diagonal to F/R pairings isnt an issue for road use?
    To plumb this lot in would be along these lines:-
    Brake fluid resevoir to both the front + rear pedal MC's and the handbrake MC
    Front pedal MC to front 2 calipers, tee'd at the MC, with a line to each front caliper
    Rear pedal MC to rear 2 calipers, single line tee'd at the rear axle
    Hand brake MC tee'd into the same rear pair brake line
    The pedal box i have has a bias balance bar arrangement, so no need for a bias valve for the rear end. Would I need to fit a bias valve on the handbrake MC to better control the handbrake action, or leave it at its full force? After all if I'm yanking on the handbrake I probably want the rears to lock up?
    Have I got that right?
    Many thanks
    BBB
    P.S. I was thinking of a seperate upright hydraulic handbrake, alongside a 'motorsport' shift tower. Similar to what you have pictured.
  4. Terry47
    Cornwall
    Hi BBB
    Yes you are almost there, but I'd change the rear set up. The output from the 'rear' m/c is then fed into the input of the handbrake cylinder and the output taken to the rear callipers. Whether the tee is in the car after the handbrake cylinder or on the rear beam does not matter. Also I'd run separate resevoirs for the front and rear lines (basically one reservoir for the front m/c and one for the rear m/c), as you already have a balance bar pedal box there is no need for a bias valve.
    You don't necessarily want the rears to 'lock up' too much but this can be controlled, to some extent, by different size m/c on the handbrake.
  5. bigbenbird Forum Member
    Alberta, Canada
    Cheers Terry......
    Forgive my ignorance, but if I 'series' up the rear and handbrake MC's.......... how does it work? I didn't think the MC would pass fluid, or does it use the fluid to push the MC, mimic ing the mechanical input from the lever?
    Like below......... ignoring the fact Ive pipe the MC's in reverse, normally the inlet it nearer the actuated end....
    Many thanks
    BBB
  6. Terry47
    Cornwall
    Yes thats it. just plumb the output from the pedal box rear m/c into the feed for the handbrake m/c (i.e. where you would normally connect the reservoir) and plumb the rear from the normal output on the handbrake m/c. You may find it a bit strange on first use as when you apply foot pressure to the pedal the handbrake goes solid, also if you operate the handbrake and then push and hold the pedal down and release the handbrake the pedal goes down even further. Nothing to worry about though, it's just the way it works.
    Just for belt and braces you may want to fit a 'saddle' onto the handbrake m/c for extra security, it stops the pushrod exiting the cylinder under very extreme hard use. Its only a small piece of metal which covers the cylinder end and is fastened with the cylinder mounting bolts with a small hole in it so the pushrod can pass through but not the ball end of the rod.
    Good luck with the installation.
  7. Jon Olds Forum Junkie
    Good stuff guys
    Jon
  8. bigbenbird Forum Member
    Alberta, Canada
    Thanks terry that's been great help
    Next question, how do I size the MC's?
    I'm going to be using mk3 golf rear calipers and porsche boxster rear calipers upfront
    Many thanks
    BBB
  9. Terry47
    Cornwall
    Hi BBB
    Just had a quick look at my own set up and I have the following;
    Front m/c 0.625
    Rear m/c 0.75
    Handbrake m/c 0.625
    My front brakes are Wilwood GNIII 6 pot calipers while the rears are standard Golf discs and calipers.
    Hope that helps.
  10. bigbenbird Forum Member
    Alberta, Canada
    Good enough place as any to start........
    Cheers Terry
    BBB
  11. mickey marrows Forum Member
    What size pistons does your Porsche Boxster rear calipers have, when I looked into them they had very small pistons which makes them almost impossible to use with a bias box...
    Example piston area:
    Girling 54 caliper: 54mm piston, piston area 4580mm2
    Mk1 Golf caliper: 48mm piston, piston area 3620mm2
    Wilwood Dynalite: 41mm piston x 4, piston area 5320mm2
    Boxster rear caliper: 25mm/27mm pistons x 4, piston area 2128mm2
    Boxster S rear caliper: 28mm/30mm pistons x 4, piston area 2644mm2
    So if you use a 5/8" master cylinder, which has 198mm2 piston area, the hydraulic ratio is
    Wilwood 26.8:1
    Girling 54 23:1
    Mk1 GTI 18:1
    Boxster S 13:1
    Boxster 10.7:1
  12. bigbenbird Forum Member
    Alberta, Canada
    Don't know what size they are
    Forgive my ignorance but what makes it difficult to use small pistons with a pedal box?
    Do I understand correctly that the hydraulic action is instantly transferred to the 'action' end. The volume being moved would be determined by the size of the MC and it's stroke
    Or is it the fact it's not servo assisted that causes issues?
    It's all new to me learning on the job!
    Are there better calipers to use on a Mk1 chassis car and 280mm discs (I don want to run wheels bigger than 15")
    Any schooling would be greatly received
    BBB
  13. mickey marrows Forum Member
    Hi BBB,
    I probably edited my reply while you were writing :)
    More info added above.
    If you apply 65kg (industry standard!) of pressure to your brake pedal, have a 6:1 pedal ratio, a 5/8" master cylinder and Wilwood Dynalites you will generate 10452kg of clamping force.
    If you swap the Wilwoods for Boxsters you would only generate 4173kg of clamping force.
  14. bigbenbird Forum Member
    Alberta, Canada
    Those numbers make the porsche brakes look naff
    Might have to look at other options then
    Can I assume those calculations are 'unassisted' forces? If there was a vacuum assut servo in the system the forces would be greater, is that right? Other than putting in remote servos a better choice of caliper will dramatically increase braking forces
    Cheers Mickey
  15. mickey marrows Forum Member
    They're not naff.. :) they're just rears... the fronts have 36mm/40mm pistons and power assistance.
    Curiously the Boxster fronts have almost exactly the same piston area as the Girling 54 @ 4550mm2
  16. bigbenbird Forum Member
    Alberta, Canada
    Having had a quick search on eBay Wilwoods dynamites aren't too dear
    BBB
