Right, I've read the internet and now my head hurts. I need links to pages to help me sort out finishing the board, the relevant specs are: MS1E v3 ABF throttle body Using the BAM VR/crank trigger wheel to run the BAM COP system in wasted spark mode. I've soldered in the TIP122 mod to run the ABF TB idle valve, added the 2 links to use the VR signal, all according to the MS-Extra build manual. What I'm stuck on is wiring in the ignition drivers, I'm ok to run the BAM COP system in wasted spark I believe, I've got 2 BIP 373/330R sets, but where do the wires and resistors go? I'm looking at diyautotunes 'using BIP 373 for ignition outputs' page, and I can't get my head around it. Is there a clearer guide out there, or has someone else got this setup working already and is prepared to share? Thanks in advance
AMK/APY/AUM/AUQ/BAM 4 wire coil packs are already amplified. So IGBTs are not required. If you can indicate where this link needs improving I would be happy to update.
[facepalm] Where on the internet was that hiding? (Yeah, in full view) Thanks, next stupid question in a bit...
On the dot com site. No questions are stupid. I had the same questions 10 years ago when I did Ben Lomas' 20v Cabrio!
